Results 1 to 8 of 8
Thread: Ran when I parked it a month ago.
    angryyoung is offline At The Back Of The Pack Arm chair racerFirst time rider
    Ontario, Canada
    164
    Exclamation Ran when I parked it a month ago.
    My ytm175 dont run anymore. I parked it amonth ago. What could be wrong? It has no muffler whatsoever, i just wanted to see if it would start for a couple seconds. I have pulled the carb, but havent looked too much at it. Any ideas on how to get this thing running will be greatly appreciated.
    Mar 2003
    West Monroe, LA
    847
    1st of all, I would not try and run the trike without and exhaust. That may also be you problem with it not cranking, you need some sort of backpressure for it to run.Without an exuast you will have none.
    86Honda250R
    85Honda250R Sold
    82Honda250R
    Tiger 200 198? Sold
    Tiger 250 198?
    Tiger 80 (need engine) Sold
    85 Tri-Z
    86 Tecate
    Perfection consists not in doing extraordinary things, but in doing ordinary things extraordinarily well.
    May 2005
    Dorset United Kingdom
    1,408
    ok the first thing you will need to do is take the spark plug out hold it against a bit of the engine with no paint with something insulated(unless it gives you a thrill to get a shock ) and turn it over, you are looking for a nice blue spark. if you dont have a spark check the kill switch and all other wiring for shorts or damage. If you do have a beautiful blue spark then its probably that your not getting any fuel, to check if this is it you can put a very small amount of fuel in the plug hole and try running it, if it does then check you got fuel going to the carb. if this doesnt work either you may have low compression or your timing may be out (unlikely if when you parked it the engine ran). you could try bump starting it so that you can turn it over for a long time i find this works somtimes to force the engine into life. hope you get it running soon
    will
    85 Tri-Z "Rumble Bee"
    85 250R "Red Rocket"
    83 200X "Flat Tracker"
    May 2005
    Nome Alaska
    147
    Great explanation, slothminx.
    Quads are for GIRLS!
    Trikes are for REAL MEN!
    Ontario, Canada
    164
    Thanks alot, ill try this tomorrow.
    Aug 2004
    Ab Canada
    4,368
    put the pipe on a clean the carb new plug.
    1985 Tri-Z-
    Hampton, Virginia, C.S.A.
    2,664
    all you need is a head pipe....and check for compression too...after you check for spark and gas
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Ithaca, NY
    2,596
    mine does the exact same thing, so dont worry. It just takes so long to get the fuel supply up because the vaccum operated fuel pump cant pump effeciently from just yanking the rope. You need to shoot a lil majic juice in there to get it to fire, then it wil make enough vaccum that the fuel pump starts working. At least thats what mine does and how I get her running. over 2 weeks of sitting its a bear to start.
    Haspin veteran '02, '03, '04, '05
    "Hey is your dash-cam on? Are we gonna be on C.O.P.S?"
    RECOVERING Trikeaholic
