Results 1 to 15 of 28
Thread: Time for a bore?
    Brandon, Manitoba
    2,209
    Time for a bore?
    I've got my cylinder apart on my YTM200. I'm getting mixed opinions on if I should bore it out. Some say do it, others say hone it. Its burning a lot of oil, The cylinder walls to not seem like they are scored.
    What else causes it to burn a lot of oil?
    What should I check?
    Brandon, Manitoba
    2,209
    Also, do you use a wire brush to clean all the carbon off of the cylinder head?
    thats what the manual says, but I thought that might be too rough....
    Jul 2004
    Mud hill. close to water !
    3,658
    Do a compression check..... got the tool ?
    Currently :
    Jul 2004
    3,658
    only bore if you HAVE to.... otherwise.. hone and new rings.
    Once you bore.. you can't go back.. once you hit the bore limit you need a new cylinder.
    No performance increase worth writing home about from a minimum bore.....
    Currently :
    Rittman, Ohio
    6,276
    You need to have it measured with the proper tools. Nobody can tell if it needs bored by the amount of oil it burns, and being smooth does not mean it is not worn.
    May 2005
    Nome Alaska
    147
    If it's burning oil, and the walls aren't scored too deep, its the rings. Just get a new piston kit and you'll be fine. You can try cleaning the carbon off with a rag and some kind of solvent first, I personally wouldn't try the wire wheel. Too scratchy.
    Quads are for GIRLS!
    Trikes are for REAL MEN!
    Rittman, Ohio
    6,276
    Quote Originally Posted by KayodicWeazel
    Im really impressed that you have the ability to measure his cylinder, sight unseen, over a message board.
    Jul 2004
    3,658
    I agree with Tim ( I'm facing the exact same delema with my XR project.. got 3 cylinders.. 1 piston.. and no micrometer.. )
    I checked on e-bay for one, but alot of cheap and expensive versions......... anyone able to recommend a perticular one ?!!
    It's a dream to some day have ALL the tools in my own garage.. not have to go places with parts for things no garage wants to do.. for free.....
    Currently :
    Jul 2004
    3,658
    How accurate is the method of putting the piston ring in the cylinder and checking the gap ? ( That's how i was told the cylinder i got would fit the shiney new piston already on the crank !!!! :yikes:
    Currently :
    Aug 2004
    Ab Canada
    4,368
    take it to the local bike shop and have them mesure the piston and bore with a micrometer for roundnesss and size, and check it against the specs in a service book is the best way, "How accurate is the method of putting the piston ring in the cylinder and checking the gap ? ( That's how i was told the cylinder i got would fit the shiney new piston already on the crank !!!! :yikes:" thats only for setting the final ring end gap AFTER it has been measure with a micrometer and honed/bored what ever was need'd.
    1985 Tri-Z-
    May 2005
    Nome Alaska
    147
    Quote Originally Posted by TimSr
    It are cause I gots the amazing psychic powers. And stuff. Actually I was just referring to what he should do generally. I'm not giving him instructions.
    Feb 2005
    washington
    58
    using a feeler gauge to check clearancesis good if you know your bore is round and not taperd. chcking size is no good if you have out of round cyinder or alot of taper!!!
    May 2005
    Nome Alaska
    147
    Actually, you know what? Ignore my posts and just send it off to a dealership to be checked. It's always better to leave this sort of thing to the certified techs.
    Brandon, Manitoba
    2,209
    or I could do it myself, saving maybe $150 in labour......
    It's not too hard to do....
    Dec 2002
    salem, nh
    1,339
    yes, listen to king tim. he is the grand master of sarcastic posts. he is always right. no one should even bother posting, just pm him and he'll give you the answer. here comes my debate of taking suggestions from other members rather than just taking tims answer.
    85 250SX New to me!!
    85 ATC 70 stock ~ TRADED
    85 ATC 70 with 138cc Lifan
    83 110 restored ~ sold
    85 110 restored ~ sold
    83 200x restored ~ sold
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    Removed choke 42 pilot DJ146 main
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    IMS Roll front bumper
    Graydon Proline nerfs
