Thread: Update on my 250R
    Nov 2004
    Waterloo IL
    2,701
    Update on my 250R
    Well I needed an engine for my 85 250R since my piston shattered and broke both of my crank cases. I found a deal on an 87 TRX motor. I accidently broke the water outlet on top of the head so I swapped my old head on it and noticed the piston was a bit loose. I ran it for awhile then I ordered a piston for an 87 250R. When the piston came I pulled it apart and the piston had 3 huge cracks. They went from the bottom of the skirt almost all the way to the top and you could see one spot where the skirt was hitting the crank shaft, this one was about to go! So I got my 1987 piston and lined up the wrist pin on the piston that just came out the top of the new piston was 5mm lower than the old one! Yep, I have an 85/86 motor. I bought it on ebay so I wasn't sure I could send the old one back but I contacted the seller and he said no problem. Lucky there.
    I also changed the the clutch cover and clutch basket. My cover was welded, leaked, and the bolt for checking the oil level was stripped. My clutch felt kinda weird, the plates had grooves worn in it. The clutch bearings were also kinda loose and full of blue silicone!
    And an update on racing the 450R's. I'm getting very close with just tuning. If my buddy gives me a half second head start he can't pass me until I hit 6th! (the 450's are tough to beat off the line, if we go from a dead stop I get beat all around by a couple bike lengths) We tried several different riders and 2 different 450R's (both have HRC kit and exhaust) and always the same results. I also have better luck starting in second, first is just too low. I have stock gearing and stock tires. I'm thinking go up a tooth on the front. I also have a 175 main and I need to try a 170. Once I have a fresh top end, gearing corrected and lean it out, it should be very close. My mods are Weisco piston, ESR exhaust, Boyesen rad valve, 36mm flat slide, CR head gasket, UNI filter with open air box. Here is a pic, its with a camera phone so it's kinda blurry.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    wanta86r's Avatar
    wanta86r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2004
    mn
    385
    sounds like everyhting is starting to work out for you. Im still trying to get my 86 R tuned in perfectly. Good luck with beating those 450's. I have a similiar setup with top end port work from esr, an atc 5 pipe, rad valve, and 38mm airstryker carb. I hope i can give the new 4 strokes a run for there money. I also am running 14- 39 gearing with sidewinder sprockets and chain. The one tooth on the front really spreads the gears out.
    sandrooster is offline At The Back Of The Pack Arm chair racerFirst time rider
    mom's house
    193
    The rear tires look kinda worn. New rears like turftamers or razrs will help both starting traction and top speed.
    Depending on the surface, if you race on loose stuff like sand, using the lightest weight rear wheels may also help.
    85 ATC250R
    Nov 2004
    Waterloo IL
    2,701
    Yeah, the back tire are some baldy's. I had brand new 18" turf tamers on back but they geared me down even more so I put the stockers back on. We race on pavement so traction really isn't a problem.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    82,79 XL500R
    83 ALT50
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72 SL100
    70,69 Z50
    Mar 2003
    West Monroe, LA
    847
    Try the 14 tooth, made a world of diff. to mine. 175 does sound a little fat, try a 165 to 170. Im running a 150 with about the same mods that you discribed. I had a 155 and it was a little to fat but we live to totally diffferent parts of the country so im sure yours will be a little different than mine. I have also run the 450R's at the sand drags, I dont think any had the HRC kit but they did have aftermarket pipes. Who ever got the holeshot ( 250R vs 450R) took the win.
    86Honda250R
    85Honda250R Sold
    82Honda250R
    Tiger 200 198? Sold
    Tiger 250 198?
    Tiger 80 (need engine) Sold
    85 Tri-Z
    86 Tecate
    Perfection consists not in doing extraordinary things, but in doing ordinary things extraordinarily well.
