Thread: axle nut problem
    May 2005
    Fort Worth,Texas (watauga)
    112
    axle nut problem
    anybody have any sure fire methods of breaking the axle nut loose?.....began doing the bearing carrier swap on the `85 and the `86........got the `86 apart no prob,but the axle nut on the `85 refuses to budge....even with pipe wrenches and a long cheater pipe1111....was standing on the cheater trying to break it loose and ended up BENDING THE PIPE WRENCH!!!!!!!
    HELP!
    trikes owned:
    1982 ATC 185S
    1983 ATC 185S
    (2) 1984 ATC 185S
    1984 ATC 200M
    (2) 1984 ATC 200S
    (3) 1984 ATC 200X
    made one an auto-x,easy swap
    1985 ATC 250R (stolen!...the bastards!...it was mint!)
    own now:
    1985 ATC 250R (running)
    1986 ATC 250R(parts bike)
    1984 ATC 250r w/ 280cc kit in it(pretty rough-needs TLC)
    1984 ATC 200s (running)
    1982 ATC 185s (running)
    (2)1984 ATC 200s(parts)
    1984 ATC 70 (parts)
    1983 ATC 70(off ebay-running)
    1985 ATC 70 (running)
    198? ATC 70 (running)
    1984 ATC 200x (running)(have made it an auto-x until i rebuild the top end of the X motor)
    1985 ATC 200x roller(gonna make another auto-x)
    Eric
    Aug 2002
    Creswell, OR
    889
    You bent the pipe wrench? Wow now thats impressive. Heat the nut. Not sure fire, but may help.
    www.3wheeler.org
    * * * Nothing scares me more than someone who knows, with certainty, what is best for me * * *
    May 2005
    maryland
    5
    try liquid wrench(wd40 like spray can) if the heat doesn't work, let it sit overnight and spray the hell out of it a few times. then wipe it off so your wrench will not slip and it should come off, just be sure not to mix liquid wrench and the heat method without wiping it off first or you trike will be fried, LOL
    Feb 2006
    Central Florida
    1,090
    her is a sure fire method...
    1. go to dratv and buy a couple axle nuts for the 110 - they should be the same as the 185 and 200's.
    2. bust out a dremel, fit it with a mandrel and a heavy cutting disc.
    you will have to cut at an angle to get as much of the nut as possible with out getting into the brake drum cover... but once you get most of the way thru the inside nut (outside nut is off by now) you should be able to put a big flat head in there and knock it counterclockwise. Sometimes you just have to break the inside nut, but sometimes the heat from cutting on it will transfer to the threads and it will come off.
    i know this is a really old post just thought i would share my destructive method.
    quiet people seem intelligent
    Sep 2003
    El Paso Tx
    1,123
    As much as I like using an oxyacetylene torch to free rusted stuff I must throw in a word of caution for the o-rings and other rubber things in the area that may become no more. Just be patient, use a spot of wd-40 for a few days if necessary and try not to strip anything as its harder to take it out. I have a suzuki gs450 I am presently having that problem as the previous owner didn't use the proper size screwdriver and monkeyed up some of the screws I need to take off now. They are frozen and have little to no place for the impact driver to bite. I may just have to resort to the tried and true caveman technology again.
    So many idiots that can't ride a motorcycle, so few hours to put my boot in their seat!
    Myeh heh heh heh heh!!!
    traxxasx's Avatar
    traxxasx is offline Alligator sized brain can't spell you correctly. Arm chair racerRoostin Away
    Sep 2005
    las vegas
    1,184
    To get castle nuts off i usually use a cross bar for lugs on cars, or a inpact.
    MY FEEDBACK---
    http://www.pbnation.com/showthread.p...2#post20992142
    +6 positive feedback.
    WaLLa BinG WaLLa BoOm ShE's DoNe!!!
    MY 225 Dx
    Piped, jetted, 2 stage uni, wheel spacers.
    __________________________________
    My 82 250R
    All original even with tool kit.
    Stage 2 uni, no air box jetted.
