does it work?? a 350x one or 250r or newer 200x light on a 85 200x? i had a 350x one on for a lil bit it kept blowing bulbs and 14 bucks a bulb, i cant afford that lol. what do i need to do?
1985 atc 110 for sale
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
uni clamp on air filter
350x front end
I'm also searching for an answer to this post. I always thought that any one you mentioned would work probably even one off an SX. Mine is cracked and melted back together. To bad maier don't make replacement plastics huh? Or you can always go with the numberplate![]()
Or you can go to walmart and buy a set of Truck lights for like 20 bucks.. Mount em up and youre good to go. It works too because my friend has one on his snow mobile.
86 Honda 200sx (needs alot of work)
82 XR200R (runs great, now the daily rider)
91 acura legend junker, selling to get a truck
2001 GSXR600 Part out, PM for info or for parts.
ya but wont you blow them truck lights? b/c they use constant power, wont the reving and getting power then not kill them?
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
350x front end
Hmm i am not sure. Someone else should know around here..
I had truck lights on my '85 X years ago. There isn't enough juice to run them both but one will work just fine. If you can find the right bulbs you can make two work.
There is a way to make a 350x light work as I've seen it done before. Not sure how it was done though. I just assumed he was using the 350x lighting coil but I have never really messed with the lights too much. A friends father got the truck lights working on my X, not me.
I thought that trikes had a regulator to keep revving from popping bulbs... maybe your machine is missing something. My 110's bulb stays the same brightness no matter if it's at idle or redline.
Quads are for GIRLS!
Trikes are for REAL MEN!
By simply adding a Volt pack you can avoid blowing bulbs ( 12volt system ). Also, I can get non halogen Bulbs that work in the 350x's and many other machines for around $3 each. In fact they are the only style I use in the machines they fit in. Sure I give up a small amount of light, but then I don't do much night riding anyway.
Howdy
uhm so far i havnt blown the 185s light...but on the 185 i put a big halogen light from my bros truck on there and it blew within 10 minutes...so i havnt done anything like that for awhile
trikes owned:
85' 200m - sold
84' 200x - sold
83' 185s - sold
82' 185s - sold
85' 350x !!! - selling
I got a Cibie (pencil beam) on my 84'
running a bulb at low wattage won't hurt it.. just dimmer.
Problem with high wattage bulbs and trikes with batteries.. is they suck alot of juice and the light drains more than the charging system can provide to the battery... one and your ok.. 2 x 35 w is pushing it .. anymore and it's too much.
Currently :
84 125 M - The Mini-SXnot running yet. but won't be long.
I have the 350x light on my 84 r spliced them too work started it and they worked for a second then blew still i could use some help on this also. its been done with working light but cant remember who did it and what they changed too make this swap successful?
Are the 2 bulbs wired in series or parallel ?
Currently :
I think they are in a series 3 wires for each bulb, im really not sure what you mean, I cut the round the plugs off the x wires, put the male flat ends on and plugged in the round r plug
madmax has 350x lights on 200x forks on his 250sx
1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
1985 honda es 250 big red.
85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
A trike to show up the modern utilitys
2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
