Thread: Problems with waterpumper R?
    Mike_Ham_250R's Avatar
    Mike_Ham_250R is offline Even team-red-rider is cooler then me. Arm chair racerJust too addicted
    Pennsylvania
    1,058
    What are the problems with the 1985 250R im goin to look at one what should i look at to see if its in good cond.?
    -Mike
    Jun 2004
    Oregon
    1,784
    Not to many that i know of...Engine pinging is one but theres really nothing you can do about that ,they all do it as far as i know.
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
    Jun 2004
    potsdam ny
    1,227
    haha yeah....
    Aug 2004
    Cedar City, Utah
    474
    The big one is the left side case by the front sprocket, chain breaks and messes stuff up, and if its bad enough it will put a hole in the case, or worse, and its not cheap to fix correctly, so keep an eye out for JB weld.
    Stripped Drain Plug, loose swingarm/linkage bushings, loose carrier bearings
    make sure the brakes work.
    Look at the brake pads see if they are worn out, check the chain and sprockets for excessive wear, look for other indications of neglect,
    Ask the seller what premix ratio they run and what brand oil.
    Remove the radiator cap and look for sludge or oil, start the bike, and look for bubbles in the water (bad head gasket)
    A good running 250R will start within 1 or 2 kicks most times.
    Those are just a few things to check, none of it is terminal, and may not mean that you shouldnt buy the bike, just be aware of what you are spending your money on, and factor in any future costs of owning and maintaining a bike like this. (and remember the bike is 20 years old! 99% of the time its not gonna be perfect.) HH
    RichinMO's Avatar
    RichinMO is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2002
    Waynesville, MO
    321
    Also, pull the airbox lid. Look for air filter (does it have one?), mouse nests, total neglect, etc. That will give you a basic idea on what the engine has been sucking into itself.
    1985 ATC250ES
    1985 ATC250SX
    1984 ATC200S "Little Red" - Trailer hitch, Hondaline: Front and Rear Racks, Cooler Rack, Tripmeter, HL Grille, Rubber Footpeg Covers, Mudflaps.
    1985 ATC70
    2008 CRF230L - Dual Sport
    2016 TRX500 Foreman Rubicon Deluxe
    Trackburger's Avatar
    Trackburger is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2005
    Virginia Beach
    254
    Oner problem I had with my 85 was that the axle carrier adjustment teeth were all chewed up, and the carrier was "froze" in the swing arm, so I couldnt adjust the chain, It really adds up when you have to start buying new carriers and what not. so look at the teeth on the left side of the carrier and ask the seller to spin it for you so you know that its not stuck in one spot. Good luck!!!
    1985 Honda ATC 250ES BIG RED
    1985 Honda ATC 350X
    1985 Honda FL670R Odyssey ROTAX conversion
    1993 Honda Type II 200
    2003 Honda TRX 90
    2006 Honda TRX 90
