Results 1 to 15 of 16
Thread: HELP.....Steering stem, triple question......
    r00sty's Avatar
    r00sty is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2002
    Hemlock 14466
    415
    Anyone know how the steering stem comes out of the lower triple tree?? Is it a pressed fit or screwed in? Thanks...
    Old enough to know better, but still young enough to not care!!!
    Reality is for people who can't handle drugs!!!
    86 XR250RX Custom but all Honda...
    92 Yamaha Vmax
    81 Yamaha XS1100
    04 Polaris 700 Twin EFI
    86 TRX 250r
    Dads is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2002
    Richmond, NH
    219
    what trike
    r00sty's Avatar
    Jan 2002
    Hemlock 14466
    415
    Didn't know it mattered, every triple I have taken apart seems to look the same, but I never needed to get the steering stem out, until now. Anyway, it is a 350x one and a XR250R one, and possibly a 200x one, depending on what I find with the first 2. Thanks....
    92 Yamaha Vmax
    81 Yamaha XS1100
    86 TRX 250r
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by Dads
    what trike
    I would say it's for his 350x. I say this because it very easy to see the ATC70 tube is welded on. But I can't answer his question. I never had a 350x tube out.
    Howdy
    r00sty's Avatar
    Jan 2002
    Hemlock 14466
    415
    Any tubes out, Howdy?? All 3 I have apart seem to be in there the same way, I just don't want to mess this up too bad... I guess I could take the less needed one and start pressing on it??
    92 Yamaha Vmax
    81 Yamaha XS1100
    86 TRX 250r
    Howdy's Avatar
    Celina, Ohio
    10,079
    I wished I could help you more roost. I haven't ever had the need to remove a tube as of yet ( in aluminum triples ). With the parts supply I got I just pull another triple tree off the shelf ( when needed ).
    Howdy
    r00sty's Avatar
    Jan 2002
    Hemlock 14466
    415
    Well this is a short thought out attempt at a custom trike, and the hang up right now is the steering stem and bearings, no prob man, I will get through it, and Project XR250RX will ride!!! Like I said, I will just go at it and see what happens, my guess is that they are pressed in, and I hope it's the short way, if not then that lower triple is never going to hold, I'll ruin the XR one first...Thanks
    92 Yamaha Vmax
    81 Yamaha XS1100
    86 TRX 250r
    Jan 2005
    Slatington PA
    4,372
    I'd say they are pressed in for sure and from reading on a motorcycle website they are not easy to get out. Might be best to take it to your favorite shop for that procedure?
    I think ALL steering stems are pressed in.
    Here is a procedure description of one guy that took them out.
    The biggest GSXR-Showa conversion problem is in the steering stem area. The GSXR forks and Guzzi LM IV forks are approximately the same uncompressed length. This is good...minimal steering geometry changes, etc. .
    The steering stems are incompatible, though. This is the pain in the butt. You have to press both steering stems out of their respective triple clamps. This is no small task, as they're both shrink fits with about 8 thousandths of an inch interference. This requires a lot of force to dislodge, and it makes a big bang when the 10-ton press finally pops them apart. Be veddy veddy careful at this point. I take no responsibility for you lodging a steering stem through your skull.
    r00sty's Avatar
    Jan 2002
    Hemlock 14466
    415
    Thanks Huffa, sounds like alot of fun, maybe I will video tape it.
    As for my favorite shop........ well, that would be me!! I have a 30,000 pound press. Thanks again.
    92 Yamaha Vmax
    81 Yamaha XS1100
    86 TRX 250r
    Nov 2004
    Fort Kent, Maine
    2,132
    Quote Originally Posted by r00sty
    Never taken apart a 350x one, but the 200x and 250sx ones are pressed in. Pain to take out, and even more of a pain to put back in.
    Phil
    '85 350X-The Flagship
    Speedo, Chrome HL Guard, Rubber Steps
    DG Chrome Power, 6-Pack Rack, White Bros Skidplate, 400ex Carb
    '85 250ES Big Red-Working in Style
    Many Hondaline & Aftermarket Add-ons
    '84 250R-Old School Racer Project
    Too many Accessories to List
    '82 200E Big Red-The Tractor
    Rubber Steps, Tripmeter
    '85 250SX-Rider
    Various Accessories
    '13 CBR250R & '05 CBR600F4i-Road Toys
    Yoshi Slip-Ons & Fender Eliminators
    Jun 2004
    geraldton, west australia
    1,068
    wow, you guys had trouble with them. i just removed the 200x one with 1 slight hit from the trusty .
    LIVELOVERIDEDIE
    1981 Honda Atc 124R-Racer project
    2005 Giant STP 1- rollin' on 26's
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Their pressed in. They come out without much problem if you've got a good press and someone who knows how to operate it. I just had to swap stems around on the 500R project.
    Live Oak, FL
    15,069
    I forgot to add, that on the CR500 clamps I had the stem pushed out of, it came from the top down. The stem has a snap ring on it, and the clamps are grooved to keep it from coming out the other direcetion (Up). Its a tight fit but it'll come out.
    r00sty's Avatar
    Jan 2002
    Hemlock 14466
    415
    Thanks alot everyone!!!
    Hey Billy, I take it you did what I am fixing to do, and fit the dirtbike stem in a set of trike clamps?? I hope the lower diameter of the bike stem is the same as the trike one, or I'll be into another modification project. Thanks again everyone!!!
    92 Yamaha Vmax
    81 Yamaha XS1100
    86 TRX 250r
    Live Oak, FL
    15,069
    Kind of roosty, I have a custom set of tripple clamps that use the larger diamter CR500 forks, but its the same principal. In the future I will probably switch to 250R clamps because of the differece in weight between the CR500 and 250R forks (CR ones are HUGE)
