Thread: oil injection?
    oil injection?
    How can I be sure that my oil injector on my tri moto is shooting enough oil in? Is there a block off kit available? Can I rig one up?
    Ithaca, NY
    2,596
    it is very unusual that it would fail. What you have to do is open the bleeder screw, and make sure there is no air in the lines, take the cover off the pump, and bleed the pump. Its pretty obvious when you take the cover off. Do this any time you unhook a line. I am running my oil injection on my 175 that sat in a field for a year, and it works fine. The housing was full of water, but internally, the pump was full of old oil. I bled all the red, crappy oil out of the system and now use snowmobile injection oil, it loves it. Dont mess with anything but the bleeder screw.
    Haspin veteran '02, '03, '04, '05
    "Hey is your dash-cam on? Are we gonna be on C.O.P.S?"
    RECOVERING Trikeaholic
    SE Minnesota
    533
    175 tri-moto
    take the tank off, and run premix if you have any concerns. I use the oil pump on mine, and it works fine. There is an adjustment on it if you feel that it is not getting enough oil.
    83 YT 175
    85 ALT 125
    SE Minnesota
    533
    When I said tank, I meant the oil tank. Not the gas tank.
    83 YT 175
    85 ALT 125
