Results 1 to 3 of 3
Thread: 1982 200s backfiring
    Apr 2005
    wisconsin
    7
    i replaced the coil,and cleaned the carb, works fine at low speeds, but when you punch it, it sputers. it eat 2 plugs today and getting worse. what could be the problem?
    wheelie king's Avatar
    wheelie king is offline Aficionado of white surprise sauces. Arm chair racerRoostin Away
    Central FL USA
    1,174
    Too rich or lean.
    Look at the plugs and do a search on this site....there are some plug "color" guides that will help you determine whether you are too rich or lean. Mixture is adjusted by moving the needle inside the sliding cylinder in the neck of the carb. Good luck
    1986 Honda ATC 200 S
    Some quads and a S x S
    Supporter of Uncle Rico's football camp. Since 1982.
    If you are reading this in English, thank a U.S. Military VET. ΜΟΛΩΝ ΛΑΒΕ
    Power_Ram100's Avatar
    Power_Ram100 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2004
    Kent, Washington
    152
    Also you might wanna adjust your valve clearances and cam chain. Both are easy adjustments.
    I just thought of something funny...your mother
    83 Big Red with Bear Claws (SOLD)
    85 Tri Z with Maxxis Alltrax rear tires on .190 aluminum rims, DG pipe, Answer SA Pro silencer, High Flow Fuel Pump, and UNI air filter (SOLD)
    99 Yamaha Kodiak 400 4x4 with Warn winch and custom skidplates
    85 Honda 250 SX with Dirt Devils (near mint) (SOLD)
