Thread: 83 Big Red 200ES Carb help
    May 2005
    Texas
    22
    1983 big red 200es, this was running great
    now, it will start and idle, but when I give it trottle, it trys to die???
    help if you can, TIA
    May 2005
    corpus christi
    13
    sounds like its getting to much fuel. when I was messing with my 200es carb. I just screwed the air/fuel mixture screw all the way in and backed it out about 1 1/2 to 2 turns. hope this helps.
    83200e's Avatar
    83200e is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    Arkansas
    356
    Clean your carb.You may get lucky and be able to just remove the bowl and spray it real good with carb cleaner.If not buy a dip can and soak it.
    83200e's Avatar
    Aug 2004
    Arkansas
    356
    One more possible easy fix,turn your gas off,drain your carb,and start it again.It may flush itself out.
    Jul 2004
    Mud hill. close to water !
    3,658
    remove the air filter and check to make sure your choke assembly is working properly and not stuck ON.
    Currently :
