"T" mark is for top dead center, that's the one you want. I think the F mark is used for ignition purposes, not valve timing. You want to set the piston at Top Dead Center (TDC) on the compression stroke. At this point both sets of rockers should have slack (unless they're adjusted too tight). As you turn the motor over, watch the valves as they open and close. When the intake valve has closed, you're coming up on the comp. stroke. I think .008 is too loose (don't have my manual in front of me), I think I use .003 for intake and .004 for exhaust. Just don't make them too tight. A tight valve will cause compression loss and eventually a burnt valve. Just hope your ticking noise is loose valves and not a wiped out top end. Saw the pics of your x, looked pretty decent. Good luck with it.
[FONT="Palatino Linotype"]~My Rides (to name a few) ~
1986 ATC250R, 1985 ATC350X
1985 ATC250R Missile (90% done)
1983 ATC185S
1999 TRX416EX
2003 Honda CBR600RR
1990 Yamaha Zuma
1985 XR80 w/100 motor
1967 Honda CB77, '65 CL77
1962 Puch 250 SGS
1984 XR350R (owned since I was a kid)
1972 Suzuki T350 Rebel, '73 T500 Titan
1964 BSA A65 (needs restored)
1968 BMW R60/2 mint original bike
1976 Kawasaki KH500 triple
Anybody have parts to trade for the above models?
