Results 1 to 15 of 15
Thread: 250sx
    new brunswick, Canada
    7
    250sx
    thinking about buying a 1985 250sx, went out to see it, wouldn't start, but the guy said he had it running on the weekend and it idled and worked great. he cleaned the carb checked for compression, spark, still wouldn't start, any ideas on how to get the bike started.
    Jul 2004
    Mud hill. close to water !
    3,658
    check for gas going to the carb....petcock..
    kick it over and then check the plug tip to see if it's dry or wet.. if dry. no gas.. means carb is cloged up.. if wet.. look for another problem or try pull starting it !
    Currently :
    7
    ya he put gas in the head, and sprayed it in the carb still nothing, we tryed kickstarting it, nothing, blew out the carb, so should be gettting gas, gas tank very clean shouldn't be glogged up
    Pa.'s Highest City
    8,058
    There's a battery in a 250sx correct? Charge it and make sure all connections are good.
    7
    elecrtical doesn't work on the bike
    Jul 2004
    3,658
    Don't need the battery to run it.. but have you put the plug on the wire.. and touch the tip to the head.. kick and checked for spark that way ?
    Currently :
    Pa.'s Highest City
    8,058
    Did you pull the plug and hold it agianst the cylinder to see if there was a pretty blue spark?
    7
    ya, the guy buys and sells trikes and he checked evything, spark was good, changed it in case not the problem, he set the valves too, said he just set time too.
    7
    my cousin was out there when it as running sid it ran good sounded nice, but now wont start at all
    CT
    674
    Try pop-starting it. Once you get them running they are bullit proof.
    86 Honda 200sx (needs alot of work)
    82 XR200R (runs great, now the daily rider)
    91 acura legend junker, selling to get a truck
    2001 GSXR600 Part out, PM for info or for parts.
    7
    ya thats the only thin we didn't try, next time im out there ill talk to him about it
    Jul 2004
    3,658
    now's the time for a low offer !!!!! :P if you make it run.. he'l want more !
    Currently :
    Jan 2005
    Slatington PA
    4,372
    Bypass the carb circut totally by spraying just a bit of carb cleaner in spark plug hole. Now try and start it, if it starts you now know it is not being fed fuel from carb.
    You can also do this method with air box off and spraying some thru carb throat with throttle opened fully. If it starts this way and you keep blipping a bit of carb fluid in and it keeps running this also tells you carb problems.
    Oops, i see some of this was mentioned already. If you have spark, fuel in cylinder, compression and timing is close to specs, it HAS to start.
    yater is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2003
    Tyler, Texas
    672
    Yep, if you've got spark, fuel, and air, it has to start....unless he's BSing about setting the timing (or did something wrong). Either way, tell him you won't pay full asking price unless it's running. Whatever the problem is, it should be an easy fix
    Nov 2004
    Fort Kent, Maine
    2,132
    It's an 85, it could have a cold start problem.
    If you can, wire the machine's electrical system directly to a 12 volt source (such as a battery charger) and start it then using the electric starter. That's how we get the Big Red to start when it is having trouble.
    '85 350X-The Flagship
    Speedo, Chrome HL Guard, Rubber Steps
    DG Chrome Power, 6-Pack Rack, White Bros Skidplate, 400ex Carb
    '85 250ES Big Red-Working in Style
    Many Hondaline & Aftermarket Add-ons
    '84 250R-Old School Racer Project
    Too many Accessories to List
    '82 200E Big Red-The Tractor
    Rubber Steps, Tripmeter
    '85 250SX-Rider
    Various Accessories
    '13 CBR250R & '05 CBR600F4i-Road Toys
    Yoshi Slip-Ons & Fender Eliminators
