Was checking everything out today.. noticed my rear end oil was contaminated ( grey and milky ) so being the " sometimes lazy " type..
Fire it up.. find a place to run in 5th for a few minutes.. warm the oil up real good. put the oil tray under the rear end...remove the fill cap.. and pick up the front forks.. (* i'm 5 foot 9.. 160 lbs.. and i found it light.. so you don't have to be hercules ).. and lifted the front to the ballance point and a bit more. And all the oil poured right out !
For you safety concious out there.. consider placing blocks behind the rear tires.... LOL...
Saves the hasle of removing the diff protector and drain plug.![]()
