Will do Jenn, Adam and I have been PMing each other back and forth about this.
Adam glad to here you got some different jets!
I would say a 120 and 40 with your needle clip in the middle groove( I know I told you 2nd from the bottom, but I think the 120 may be a touch big so try the middle groove)
Since you have a 40 pilot jet go about 2-1/4 turns out on the pilot screw.
This set up should be enough fuel to get the machine running.
I don't understand the "shocking" thing, that has me baffled
, only thing I can think of is if you painted everything and the coil and engine aren't making enough contact with the frame and isn't grounded
The screw on the side of the carb is the idle screw, it raises the carb slide when it is screwed in....Make sure you are giving it throttle while turning this screw in or the screw will ding up the adjustment ramp on the slide.
If you can get it started by pulling or kicking, let it sit there and idle for 5 minutes and shut it off and check the plug. At least you would know if its getting enough fuel for idling.
I'm headed to the raceshop to pull the motor out of the racecar, maybe if I get home at a decent hour I'll check back on here.
Jeff
1983 honda 200x
webcam
12:1 powroll piston .75 over
DG Xccelerator stage-3 exhaust
26mm keihin XR200R carb & intake
UNI filter using modified air box
VP C12 racing fuel..$6.50 a gallon
Barnett clutch and H/D springs
13/38 20" turf tamers
stock gearing for 22" winter tires
wooohoooo its bad fast! For a 200X
1988 kawasaki mojave
