Results 46 to 51 of 51
Thread: Help On 200x Motor Troubles
  1. #46
    200xadam's Avatar
    200xadam is offline At The Back Of The Pack Arm chair racerFirst time rider
    Michigan (Britton)
    193
    would it be possible for me to put an entire 200s wireing harness on the x motor..? i have a complete s motor and i tried putting the s cdi box on it but it didnt work but could i put the wireing harness from the s on it?, just to see if my coil or something is my problem??
    2000 426Ex
    Too Much In The Motor To Talk About
    +2+4 Axle
    Lowering Kit
    FCR Carb
    !*Under Construction*!
    2005 Blaster
    cb750 4cylinder motor
  2. #47
    Northern Wisconsin
    19
    I would have to say no since the test specs are probably different between the two...I will check tomorrow when I get home from work, just for reference what year is the 200X and what year is the 200S? I'll need to know for cross reference.
    I am pretty sure you can't use the S coil on the X though and that would mean that you couldn't use the entire S wiring harness if I'm correct.
    Jeff
    The ohms test for the X coil is as follows;
    Take the coil off the trike and test with multi-meter set for ohms.
    1 lead to mounting hole, other lead to spade terminal= 0.2-0.8 ohms of resistance
    1 lead to mounting hole, other lead to plug wire boot= 8-15k ohms of resistance
    If you coil tests within these specs the coil is GOOD.
    Jeff
    1983 honda 200x
    webcam
    12:1 powroll piston .75 over
    DG Xccelerator stage-3 exhaust
    26mm keihin XR200R carb & intake
    UNI filter using modified air box
    VP C12 racing fuel..$6.50 a gallon
    Barnett clutch and H/D springs
    13/38 20" turf tamers
    stock gearing for 22" winter tires
    wooohoooo its bad fast! For a 200X
    1988 kawasaki mojave
  3. #48
    Northern Wisconsin
    19
    Heres the rest of the electrical tests for the 84-85 200X, if you need the specs for a 83 let me know(only the CDI test is different)
    Check with ohm meter
    Alternator test
    black/red wire to CDI engine cover is normal if there is continuity and 100-400 ohms of resistance
    pulse generator (behind CDI engine cover) test
    blue/yellow and green wires 50-150 ohms
    also make sure the spark advancer behind the CDI engine cover moves freely.
    CDI test with ohms tester
    You will have to note the cover of the wires on the connectors and test the CDI spade terminals as if they were color coded the same as the wires. Don't know how else to explain this.
    First color listed is for the positive wire of the tester.
    BLK TO GRN=.5-100
    BLK TO BLK/RED=.2-20
    BLK TO GRN=.5-100
    BLK TO BLUE/YEL=5-200
    BLK TO BLK/YELLOW=CONT
    GRN TO BLK=CONT
    GRN TO BLK/RED=CONT
    GRN TO BLUE/YELLOW= .5-100
    GRN TO BLK/YELLOW=CONT
    BLK/RED TO BLK=CONT
    BLK/RED TO GRN=.2-20
    BLK/RED TO BLUE/YELLOW=2-100
    BLK/RED TO BLK/YELLOW=CONT
    GRN TO BLK=CONT
    GRN TO BLK/RED=CONT
    And finally positive lead to blue/yellow and negative to every other terminal should have continuity.
    And positive lead to blk/yellow and negative to every other terminal should have continuity.
    Yes thats a whole lot of testing for a little CDI!
    Good luck
    Jeff
    1983 honda 200x
    webcam
  4. #49
    200xadam's Avatar
    Michigan (Britton)
    193
    what is the spark advancor becase i might have that held down or something?? im really out of ideas now man and im about to the point of giving up nothing makes this thing work, im goona try n buy a used wireing harness for cheap that someone knows is good just to make sure
    2000 426Ex
    +2+4 Axle
    Lowering Kit
    FCR Carb
    2005 Blaster
  5. #50
    Northern Wisconsin
    19
    Its under the cover marked CDI, the advancer is the center thing, you should be able to move it freely left and right a little bit. There should also be 0.014-0.020" air gap between that and the black rectangular box above it when the marks line up.
    Jeff
    1983 honda 200x
    webcam
  6. #51
    Northern Wisconsin
    19
    ADAM
    Any new updates?
    Jeff
    1983 honda 200x
    webcam
