Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 39
Thread: Need help and Advice on pulling an SX motor out of its frame.
    springville, PA
    6,185
    The last time I did this my neighbor did most of the work and we pulled the drive shaft out of the engine causing all the gears to fall out of place so what I need to know is...
    1. how many mounting brakets hold the engine in?
    2. where should the drive shaft be separated at?
    3. how many bolts hold the head on?
    4. is there any electrical, mechanical, ect... that i need to unhook before I take it out? I already know to unhook the carb boot and oil cooler.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Quote Originally Posted by 250sxwheeliepop
    There are front brackets, top brackets and frame mounts.
    Slide back boot and pry off splines
    A bunch of 8MM head bolts
    There is no oil cooler. Starter positive and ground are connected along with a plug from the ignition side. A reverse and nuetral plug.
    Reverse cable and foot pegs too.
    That engine is HEAVY and a tight fit too. Rolls out the right side, good luck!
    Aug 2004
    Ab Canada
    4,368
    Are you sure your timing chain just didnt pop off befor you pull the whole motor?
    1985 Tri-Z-
    springville, PA
    6,185
    Quote Originally Posted by My trike Sucks
    I have no compression
    Nate
    R.I.P HRR
    Aug 2004
    Ab Canada
    4,368
    yes and a timing chain would cause that if one or more valves stuck open.
    1985 Tri-Z-
    springville, PA
    6,185
    Quote Originally Posted by Dirtcrasher
    what is the line running up to the right side of the head? It starts on the right top of the engine and runs up there.
    so I have to take the exaust pipe off to?
    Nate
    R.I.P HRR
    springville, PA
    6,185
    All I want to do is look at the piston which means the head had to come off, which means I could look at the chain, but there isnt enough room to get all the head bolts off because of the lack of room. So i have to take the engine out.
    Nate
    R.I.P HRR
    Aug 2004
    Ab Canada
    4,368
    I say this becuse motors just dont all of a sudden have no compression from a 2 second ride if it was fine the day before(normally lol) what im thinkin is your mom was usin the elcltricstart and it startted and she kept on the electric start button and it coulda back fire'd n sent the timin chang flyin (if it was loose)...just my 0.2 cents...could save you time to check it! , you can just pop the pulse rotor cover off and see if the chain is still on and tight, takes like 5 mins..
    1985 Tri-Z-
    springville, PA
    6,185
    oh so i dont need to take the head off?
    Nate
    R.I.P HRR
    Aug 2004
    Ab Canada
    4,368
    ...you dont have to take the head off, just the rocker cover, hell to make it really easy yto see whats goin on just take the valve adjustment caps off and crank it over see if your valves move, if they dont you know its a cam chain.
    1985 Tri-Z-
    springville, PA
    6,185
    are the caps on the head? and I just got done reading the 350X ticking thread and mine was ticking for a while and it still was up till yesterday. I see one of the replys is a loose timing chain. So I hope its just that simple.
    Nate
    R.I.P HRR
    Aug 2004
    Ab Canada
    4,368
    yes they should be on the head. up there someware..lol
    1985 Tri-Z-
    Opelousas, Louisiana
    1,337
    that line running from the crankcase to the head is not for a oil cooler it is just to get more oil up to the head instead of going through like the 200 engines.
    1986 350X K&N filter, DG Krome Power exhaust
    1982 110 UNI filter, Cobra megaphone exhaust
    1982 honda 110 exhaust for sale, PM me.
    There are quite a few possible reasons for no compression - snapped connecting rod, broken crank, broken cam, sheared timing chain sprocket key or bolts in the upper sprocket and so on. Simply remove the 2 - 8mm bolts holding the cam chain tensioner in place and if it pops out 1/4 of an inch then the chain isn't snapped. Generally the head gets pretty noisy if the chain is on the way out. I too would remove the valve cap cover and check out the cam etc (there is no pulse generator cover with t chain access) The book says that the rocker arm cover comes off in the frame but I had difficulty in removing mine. I had a dowel pin stuck in the head which prevented it from slipping off so I just yanked the motor.
    springville, PA
    6,185
    i took the valve covers off and the valves are moving just fine. SO i dunno whats wrong.
    Nate
    R.I.P HRR
