I have an '85 and have 6 pipes in the garage. The one I run on the bike is a Bill's Pipe. The problem is that you can't buy them. They will not make them. I have called and talked to Bill and he said "those jigs have been put away long ago". I have a Paul Turner Hi-Rev that screams,but you have to keep the RPM's up which does not really suit where I ride the most. I also have a Coffmans hand built sectional cone pipe that is a short fat low end track pipe that the power hits as soon as you hit the throttle,but not good for out riding the dirt roads and levees I ride. I have a DG pipe that is a good all around pipe and your best value. They are probably the most economical pipe and better than stock. You just have to remember that a Hi-Rev pipe does not mean your bike will be faster,it means you have to keep the RPM's up to be in the power band. A Low-End pipe does not make your bike slow, the power band just hits sooner. I have so many pipes because I did not understand how a pipe worked on a 2 stroke so I kept trying different ones until I found one that made my bike do what I wanted. I bought the Paul Turner because I thought it would make it faster,which it did but I could not trail ride. I always had to be in a lower gear and have the bike reved out all the time. I would have been better with the Type 6. The DG was the first pipe I bought just because it was the cheapest chrome pipe avaliable. Deceide how you ride and do a little research of what an expansion chamber does. It is not an exhaust pipe like a 4 stroke. A short fat pipe is for low end and a longer skinny pipe is a high rev pipe.
I would rather have a sister in a whorehouse,than a brother with a quad!!!!!!!!!!!!!!!!!!!!!! Still walking the "Tightrope"
