Results 1 to 15 of 18
Thread: Question about 350x airbox tubes
    Dec 2002
    SW Alabama
    763
    Here is what I have: Building a 350x out of misc. parts. The air box hasn't been on a trike in many years. The tube that connects the box to the intake side of the carb is hard as a rock. It also has aparently srunken as it aged. It is too small to fit the carb. Too stiff to stretch. Will not go on even when coated w/ grease. What can I do to make it flexable again? This is holding up the whole project. Thanks for any and all help.
    Trikes: Cagiva 200, 85? Tiger 250,(2)84 200x's , (3)86 200x's, 87 200x, (5)85 350x's, (2)86 350x's, (2)85 250r's, 86 Tecate, (3) 85 250sx's Restoring: 83 200x, 86 250sx. Too many utility trikes to list.
    Ashland City, TN
    2,576
    Buy a new hose.
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    86350X is offline At The Back Of The Pack Arm chair racerFirst time rider
    I'm not sure, but you might want to try heating it up with a heat gun,,, also try soaking it in carb cleaner, it softens and expands rubber parts.....
    2003 honda shadow 1100 spirit
    94 XR600R
    70 qa 50 with a 90cc motor in it
    87 XR80R
    82 XR500R
    1972 Honda z50A mini trail,,, Finally got a stock mini
    1981 CR450R
    2004 chevy silverado ls ext. cab 4x4 5.3L
    Aug 2002
    332
    I had the same problem on my 200X back in the day. If it doesn't have any metal in it, put it in the microwave for 10 seconds or so and try it. Works great!
    YOU MUST MAKE SURE THAT IT DOESN'T HAVE METAL ON IT.
    Sorry, it had to be stated.
    Joel Morris
    Purdue University Graduate Student
    Mechanical Engineering Technology
    1985 ATC70
    web.ics.purdue.edu/~jsmorris
    Nov 2001
    B.C.
    933
    Never use petroleum products on rubber! They are not compatable and hasten the deterioration of them!. To soften the tube, dip it into hot, hot water. This softens the tube enough to work it over the carb mouth.
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    Don't be cheap! Go buy a manual!
    The carb cleaner I am talking about is not petrolium based,,,, and like I said, try heat first,,,,,, Good luck
    94 XR600R
    87 XR80R
    82 XR500R
    1981 CR450R
    Minnesota
    784
    Maybe you have a larger carb and that is why it won't go on? Take a look on ebay at some 350x carbs and see if they look the same as yours.
    just happen to have pics of the carb!
    Work smarter, not harder
    Rides:
    '85 350x
    '80 cb650c
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    Looks like a 350X carb. Im with the rest of them, use a heat gun. When the tube is hot, it will go on easy.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
    Minnesota
    784
    are those two pictures of whitemans 350x carb or one off ebay?
    Don't know. Had em saved to my computer for a while. Don't remember where I got em.
    Rides:
    '85 350x
    '80 cb650c
    Dec 2002
    SW Alabama
    763
    The carb is stock 350x. I currently have 2 w/ the original carbs on them, and 3 more extra carbs. They are all the same size. The carb being the wrong size is the first thing I thought of. I got the others out to check and it is the same size.
    Nov 2001
    B.C.
    933
    Carb cleaner is just solvents! It will eat the rubber just as quickly!
    May 2002
    610
    How about using a universal K&N air filter with an outerwear and hooking it straight to the carb? Just a thought...
    Sam from Florida
    1985 BIGRED $ 200X
    Dec 2002
    SW Alabama
    763
    Well, I am trying to build this thing out of existing parts. Can't really spend more $$ in it. I have to get it out of the way so I can start on the Cagiva. Thanks for the advise tho. If I could afford it I would put a k&n on it. But, I really need to use what I have.
