tsubaki is def better than oem, unless oem is made by tsubaki!.....ebc is def way better than vesrah or probably oem which could possibly be made by vesrah....ebc is good stuff, and from my experience with vesrah i wouldnt put any of their engine parts in my engine...
i second that!Originally Posted by hrc85250r
1985 Tri-Z-
Originally Posted by mywifeknowseverything
When it comes to clutch plats i would stick with oem. Its been 20+- years that theyve lasted, none of the aftermarket ones are going to pull that off.
Should I get the metal plates too? I dont know any aftermarket place that makes them, most just make the fibre disk/friction plate
Thats because you have to really jack somthing up to runin the metal plates. You can bring your metal plates back to life by rubbing them on cement in a small circular motion to make them rough again.
Make sure they aint warped on a pieces of glass, just lay em on and you will see if they are or not.Originally Posted by Yamahauler
1985 Tri-Z-
just to let you guys know...ebc makes vesrah...lol...i found that out the other day from the guy at my local shop...and braking brakes i guess is waht the company called makes ebc...so if you dont want oem prices and braking brakes pads are cheaper than ebc or whatever..its the same thing..just buy the cheaper brand
trikes owned:
85' 200m - sold
84' 200x - sold
83' 185s - sold
82' 185s - sold
85' 350x !!! - selling
Currently using an EMGO shift lever on my SX.. universal shifter.. got it at honda shop. 20 $ with bolt, rubber and everything included. so far so good.. but it's still pretty new !!!
the oem one was a fortune !!
Currently :
84 125 M - The Mini-SXnot running yet. but won't be long.
They may be made by the same company but they are not the same quality.Originally Posted by 83185s
yea i know...the brake pads are the same quality tho..the guys at the shop run the cheap pads and have for years and said that they havnt gave up yet...hes got them on his 250r quad and his z 400 quad...he says they are dam good...i dunno i just thought id give my .02
trikes owned:
85' 200m - sold
84' 200x - sold
83' 185s - sold
82' 185s - sold
Run them yourself and then tell me what you think. I've ran more pads then you've mentioned and you CAN tell a differnce, just my .02 cents, not someone elses.Originally Posted by 83185s
