anyone know how to set the time on the atc or check to see if it on ????thanks in advance
anybody?help me on this one
Try and keep it all in one thread.... people here like that .
Yes .. alot of us know how to do that.
Have you done anything that would have affected the timing ? was it running before ? when did it last run ?... if you have a dry plug.. start there before you create more problems for yourself.
Currently :
84 125 M - The Mini-SXnot running yet. but won't be long.
Check the manual and see where the little dot on the cam gear is supposed to point to.
Rides:
82 atc 200e
83 atc 200e
76 chevy k20 custom deluxe
01 ford f250 diesel
1938 Nash Lafayette
1925 Nash Ajax
My band:
www.myspace.com/epicosgiliath
make sure the cam lobes are pointing down towards the flywheel while thr T mark on the flywheel is lined up with the mark on the case(baicly pointing straight up) put the cam gear on and line it up with the cam lobes, pointing down throw the chain on and whala timing in a nutshell.
1985 Tri-Z-
Originally Posted by mywifeknowseverything
