Results 1 to 11 of 11
Thread: 185s motor upgrades
    May 2005
    Hobart, Oklahoma
    570
    185s motor upgrades
    I'm now looking to upgrade/fix the engine on my '85 autoX with the 185s motor in it. What can be done to this little engine to perk it up a bit ? I've asked before about the 200 top-end swap and decided that would be a waste of time based on the responses . It has the 200x carb and a cobra exhaust, but other than that its stock. It is smocking bad so it is going to need a new set of rings or a complete bore/piston . Would a different cam or a high compression piston make any difference?
    Thanks!
    P.S. I've got film being developed hopefully soon I can get some pics up.
    Nov 2002
    Kirkville, NY
    3,831
    Since you need a top end job and already have a 200x carb. I would get a 200 cylinder and a wiesco 10.25:1 compression piston. If you like riding in the highter RPM range then you might want to look for a 200X cam or XR200 cam. Venting the airbox and going with a high flow air filter would help some too. As always it depends on how much money you want to spend. Remember to rejet after you change anything.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Jul 2004
    Mud hill. close to water !
    3,658
    Port and polish.
    10.5 : 1
    Currently :
    faf_racing's Avatar
    faf_racing is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2005
    pensacola florida
    187
    Quote Originally Posted by bigredhead
    Port and polish.
    10.5 : 1
    After you build the motor up too scuff. I run no air box just strait k&n out the back....... some say thats wrong, and drill holes in the air box.... why?? is there a differance?
    Anaheim
    1,270
    well if you just drill out the air box you then have some protection from mud and water. if you just put the air filter on the back with a prefilter it doesnt do a good job in wet climates. i say 200x head and cylinder 10:1 compression web cam and be happy the thing will scoot pretty good
    adam
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
    Jun 2004
    Brazil, Indiana
    1,389
    ight heres a short list that will hop that lil sucker up:
    200x parts- carb, 10.25:1 wiseco piston, complete top end,
    midsized webcam, dg or cobra exhaust, ....prices, if you get the top end from ebay which wil run around 40 and then the cam is about 110, the carb is another 20 from ebay, piston kit- 80 , bore job 20-40 , pipe 100-175 , the total of the biggest numbers there is 465...you can prolly get some cheaper than that
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
    May 2003
    Shediac, New Brunswick
    1,126
    You dont need the 200x head, its the same as the 185 head. A 200x cylinder has larger cooling fins and the sleeve is bored 2mm more than the 185. Now you can just bore your 185 sleeve out 2mm and it will be the same as a 200x... you can use a 200x piston. (You will still have 2mm left on that sleeve also.
    Now for the cam I have heard 2 things. Some people say that all 185-200cc honda trike cams are the same, including the 200x, other people say the x one is different I do not know.
    I say bore your 185 cylinder out. Find a larger camshaft. go higher compression piston with a pipe and filter.. and your 185 engine is about maxed out...
    Other than porting and stroking (but I dont knpw if you can stroke a 185 shaft...)
    Anyways thats my input.
    '84 Honda 200x
    slow restro
    May 2005
    Hobart, Oklahoma
    570
    Money is not a huge problem, but I don't want to go crazy . I forgot to mention that it has a Moose air filter with no air box lid. The Cobra exhaust is fairly new and will stay. I have also changed the sproket ratio from 11/42 to 12/40. I have heard the same thing about the cam being the same and also have read that they are different. If anyone can clear that part up it would be great . I was looking on ebay and there is a company that sells a complete topend replacement with piston, gaskets, the jug and everything you need for around $140. Is that a good deal? They also sell a kit that comes with the above stuff plus valves, cam chain, and some other things for $230. Would it be cheaper to buy my own piston kit and have a local gut bore it and put it back together?
    Jul 2004
    3,658
    If the kit is " New " hardware.. i think that's a good deal.... leaves you with your originals that you can re-sell on e-bay to recoup some money.....
    Currently :
    Opelousas, Louisiana
    1,337
    kn filter, dg pipe, web cam, wiseco piston, port/polish.
    i would probably go with a 10.25:1 piston (i would NOT want to run race fuel) and mid range cam.
    1986 350X K&N filter, DG Krome Power exhaust
    1982 110 UNI filter, Cobra megaphone exhaust
    1982 honda 110 exhaust for sale, PM me.
    Jan 2005
    Michigan
    135
    seeing it will be apart id install new timming chain and tensioner dont want them to take out the motor after you just put all that into it !!
    85 200X
    4" supertrapp
    66MM 12:1
    82 Big Red
    85 Tri-zinger
