Results 1 to 15 of 20
Thread: Does anyone know why My honda is harder to start in the winter
    svo58 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2004
    clifton park,saratoga county,N.Y.
    166
    My honda's are harder to start in the winter,in the warm weather they start rite up.Am i doing something wrong with tuning.In the cold i get a little carbon build up on the plug(84 big red 200es) and i have to clean it.What am i doing wrong with tuning it up.The engine does not smoke at all,it idles good in warm weather ,in cold weather it's ruff running when idles and harder to start.Any help and or tips would be great.I put New plugs ,rebuilt the carbs.When i used dr8es-L the plug gets dry carbon on it .I looked it up and they said the plug was to cold, i went with a dr7es-L .It started a little better ,but if i rode it a short time 2 to 3 min and only 1st and 2nd gear the plug would have carbon on the tip and i would have to clean it and it would start rite up again.Any help would be great,thanks........svo58
    84 big red 200es with speedo
    84 70cc ATC- new top end ,rear rack, head light and tail light
    85 250es big red
    85 250sx
    Nov 2004
    Fort Kent, Maine
    2,132
    Could be the jetting? Hard starting in winter is normal, but the plugs shouldn't behave like that.
    '85 350X-The Flagship
    Speedo, Chrome HL Guard, Rubber Steps
    DG Chrome Power, 6-Pack Rack, White Bros Skidplate, 400ex Carb
    '85 250ES Big Red-Working in Style
    Many Hondaline & Aftermarket Add-ons
    '84 250R-Old School Racer Project
    Too many Accessories to List
    '82 200E Big Red-The Tractor
    Rubber Steps, Tripmeter
    '85 250SX-Rider
    Various Accessories
    '13 CBR250R & '05 CBR600F4i-Road Toys
    Yoshi Slip-Ons & Fender Eliminators
    Jul 2004
    Mud hill. close to water !
    3,658
    Same here.. my SX can be a hog in cold weather ( Thank god for electric start !! )
    Cold air has a different density than warm air.. adjusting the air/fuel mixture should help as well as adding fuel stabilizer to your gas.
    Currently :
    Opelousas, Louisiana
    1,337
    i dont know, but my 110 is killer to start in the winter. i go hunting and am dressed all warm by the time i get it started, i am in a t shirt sweatin like a hog. (alot of cursing too)
    1986 350X K&N filter, DG Krome Power exhaust
    1982 110 UNI filter, Cobra megaphone exhaust
    1982 honda 110 exhaust for sale, PM me.
    Jul 2004
    166
    So these honda's are hard starting in the cold,what plug do you use in the 200 honda's.The book said dr8es-L ,mine runs better with dr7es-L,But what's up with the carbon on the plug,i can't figure it out.
    85 250es big red
    85 250sx
    Jan 2005
    Slatington PA
    4,372
    Going down to a lighter weight oil will help some. Under 30 degrees try a 5 or 10W30.
    springville, PA
    6,185
    any vehicle with a carb is hard to start in winter. That includes hondas, yamahas, suzukis, kawasakis, ect. just use the choke and after it is warmed up take the choke off. If you are running too rich you will get carbon buildup on the plug. play with the fuel\air mixture screw till you find the perfect spot. that should help keep the carbon buildup to a minimum.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    250rAL is offline Just Too Addicted Arm chair racerJust too addicted
    Sabula,IA
    620
    Quote Originally Posted by 250sxwheeliepop
    You must only have 4 strokes. Both of the 2 strokes I have(250R & Blaster) start just as easy in the winter as the summer. I've also got 4 strokes and they're generally a pain in the winter.
    __________________
    '85 ATC250R
    .030 Over Wiseco
    FMF Pipe/Answer silencer
    36PJ Keihin
    K&N
    Boyesen reeds
    Magura hydraulic clutch
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
    Three Wheelin' Since '84
    springville, PA
    6,185
    yep I'm a 4 stroke man
    Nate
    R.I.P HRR
    Jul 2004
    3,658
    Another detail.. you said you were checking the plug after a few minutes of run time... this might be mis-leading.
    Put a new one in ( should start easier with a new plug anyways . wich is another detail ! ) and get it warmed up (using choke. wich makes things very rich.. heavy on fuel. low on air ) this will make a plug go black naturaly.. but then if you remove choke and go for a long ride.. i'm talking a few hours worth of riding .. then remove the plug and check it then.. i bet you it looks pretty normal.
    But cold air and summer hot air combined with moisture you get a different burn.
    Currently :
    Quote Originally Posted by svo58
    Some models had a service bulletin on "cold starting" the SX is one of them and they offer a now discontinued kit to remedy it. If yours doesn't have a bulletin than it is most likely a problem in the starting circuit. Could be as simple as a damaged air screw or o-ring or a dirty carburetor passage/jet. My SX's all start without any problem in 15 degrees. Of course the choke stays on a bit longer but the initial start up is no problem. I don't have a carbon build up either.
    Jan 2005
    RI
    2,530
    my 200s and suzuki quadsport start first kick/pull everytime, i just have the choke on for a little longer...
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Check the intake valve lash for propper tollarances.
    wheelie king's Avatar
    wheelie king is offline Aficionado of white surprise sauces. Arm chair racerRoostin Away
    Central FL USA
    1,174
    My 200s is a BEAR to start in the winter. The yammies crank right up. My buddies love to point this out...... I'm a Honda Guy. Thank god that down here we only have ONE MONTH of COLD!!!!
    1986 Honda ATC 200 S
    Some quads and a S x S
    Supporter of Uncle Rico's football camp. Since 1982.
    If you are reading this in English, thank a U.S. Military VET. ΜΟΛΩΝ ΛΑΒΕ
    Jul 2004
    3,658
    http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
    I'm hoping this will help my SX some !!
    Currently :
