Thread: Flushing the Crank
    Jan 2005
    Spruce Head Island, Maine
    893
    Question Flushing the Crank
    what is the proper procedure to flush out the crank, what should i look for... the arm (brain Fart) that the piston goes on wobbles a bit.. is this ok?? and it makes grinding noises as i turn it.. bearings that i can see (left side) look ok..
    1983 Honda ATC 200x-shes a beater
    Past Rides:
    1982 ATC Big Red 200e (miss it more than i thought i would)
    1985 200x rode it for about a mile
    Aug 2004
    Ab Canada
    4,368
    there shouldnt be a grinding nois, there should not be ANY play UP and DOWN on the connecting rod, some side to side is ok aslong as its in spec...
    1985 Tri-Z-
    Jan 2005
    893
    there is no up and down play, just a little side to side... im going to flush it untill i no longer hear grinding.. i hope this crank is alright... the other motor knocks hard, and i need to get this one together to throw in it..
    Past Rides:
    Aug 2004
    Ab Canada
    4,368
    If there is any rust in there on the bearing surfaces its junk, rebuild it.....if you see rust on the crack weights then its prolly on the main bearings too and they need to be replaced
    1985 Tri-Z-
