Originally Posted by
83185s
ok the thing moves with my hands very easy..but not with the rim as it spins...and i have no idea as to how to take it off...i dont even know anything about it really...all i know is that i looked at my dads goldwing and our kz 400 motorcycles and it looks liek them kinda..so i suppose its a speedo..and it spins and i dont think honda would have something on there that does nothing..lol..i dont see any threads tho..which could explain why there is no cable or meter...i bought the trike from a friend..for 150...it had no engine or a bunch of other things when i got it..and i thought that thing might have just been a spacer or somethin...now that i know it is a speedo gear thingy i need to find out how it should work..i was thinkin of welding a little piece of scrap metal onto my rim and makin it go in that little space on the speedo gear..but seeing how its gold and looks good i prolly wont...lol..i was also thinkin about jb weldin it and seeing what happens...btw..it spins pretty fast when i spin the little thing by the rim ...i think it goes 1 rotation for the rims rotation...does that even sound right?? anyway..i just thought id add some things about it...i took the tire off the forks and took off my disk and polished up the rim...it looks shiny now! lol...hopefully i get my stator tomarrow so i can go ridin with my friend on his 400ex...
I'm assuming the little tab off your hub is broken. Why don't you take a picture of it.????...Your 200X hub should be similar to my 350X hub.. look at the first pic below... see the tab? That goes in the notch in that ring. Those pics should also help you figure out how it comes off/on. Once it's off, that ring against the hub will come off so you can grease/oil it up good. The 82R is similar idea, but has the old school metal hub instead of the cast hub. I included 3 pics of that for you too.
Maine Triker.... The tach attaches to the coil and that "extra wire" behind the headlight. Those darn left hand gearboxes.... I got a couple of them here.... 200X or 83/84R I guess...
They look like the 350X ones but turn the other direction. Now you said something about modifying the display... that won't work... only way you can use a 200X gearbox on a 350X is to turn the forks around backwards...not that I'd ever stoop that low to make it work.
Swinehart ... That's some mighty nice Tach documentation you got there!
hehehhee
Bruce
'86 ATC350X - 'Go-Go Girl'
'85 ATC70 - All Original
'83 Suzuki ALT125 - Pieces
