Results 1 to 15 of 28
Thread: 1983 atc 200 carb need help
    jackson (area) tn
    27
    today i cleaned the carb lol it probaly was my prob but know i have another problem there is a screw with a spring on the bottom of the bowl but on the outside of the bowl does this have a little washer if so does the washer go in before the spring or after ?lol and how tight do i retighten to ???????please help thanks in advance
    jackson (area) tn
    27
    anybody with atc 200 83?????
    jackson (area) tn
    27
    come on anybody gonna help big where * at lol
    Duluth MN
    803
    i never have taken it apart that far, however i will be taken it apart tomorrow, ill check 4 ya and let you know
    Confused As A Hungry Baby In A Topless Bar!!!
    '04 Honda CRF250R
    '82 Honda 200 4'sale soon
    '90 and '91 Arctic Cat Prowler 440
    '81 Kawasaki LTD 440 Belt Drive!!
    '92 Yamaha Warrior 350
    '05 DS 90
    Helmet save'd my friend's life, and mine, wear one!!!
    Trying is the first step to failure
    3ww Needs an iPhone app
    Jan 2005
    RI
    2,530
    Maybe if you gave people time and we could read what you typed/said, someone may be able to help you.
    A clymers manual will tell you all the information you need.
    jackson (area) tn
    27
    well im new here and i guess the afternoon crew aint so grouchy lol and why dont someone have a page or two out of the maual thats what the internet is for so i thought anyways same prob hope someone will help thanks in advance.....
    Aug 2004
    Ab Canada
    4,368
    There is no "washer" for the air/fuel screw (you are talking about the upsidedown slotted one right? ) you have to play with it n run plug chops till you feel its right, in =richer out=leaner...hope this helps...if its the same screw where talkin bout here..lol
    1985 Tri-Z-
    jackson (area) tn
    27
    its on the bottom of the carbon the edge in the middle ,lolnot the one to drain the bowl
    Jul 2004
    Mud hill. close to water !
    3,658
    go to www.partsfish.com and look up the diagrams for the carb.. easy to do.
    I'll check my manual in about 20 minutes. yeah it's the air/fuel screw .. i beleive it has the spring and that wather on top so the spring does not dig into the carb body .... be back in a few.
    Currently :
    Jul 2004
    3,658
    ok specs for ATC 200.. plain 200..
    Model:PD 35C
    Main Jet No. 105
    Initial pilot screw opening 81 - 2 turns out.. 82 - 2 1/8.... and 83 1 1/4 TURNS OUT !!
    Needle Jet/Clip : 2nd gove
    Float Level : 0.49 in ( 12.5mm)
    Idle Speed: 1400 RPM + - 100
    The pilot screw assembly should be
    Bolt ... then put the spring on.... then the Flat Washer.. and then the RUBBER O-RING
    then put all this into the carb... Turn all the way in until it seats.. don't overdo it as you don't want to crush the o-ring also make sure the old one is not still in there... or you will have problems.
    Once you feel it bottom out slightly.. then turn 1 1/4 turns for the 83 and it should fire right up and you can adjust it after it's on the bike.
    Currently :
    jackson (area) tn
    27
    lol so the washer goes into the carb the put the spring in the carb the the bolt o ring ??????
    Jul 2004
    3,658
    picture the carb in your left hand....
    with the right hand.. put in the
    0-ring first.
    Then the Flat metal washer
    Then the spring
    Then the nut.
    Currently :
    jackson (area) tn
    27
    * the the man 1 more lol then ready to start. the side screw it has a spring visible any suggestion ?
    jackson (area) tn
    27
    it is screw set b thats what the carb diagram says it is
    Jul 2004
    3,658
    That's the idle screw.
    In all the way and then out 2 turns for starters... IN will make it idle faster..
    OUT will slow down the idle.
    Currently :
