Results 1 to 6 of 6
Thread: No spark
    Duluth MN
    803
    No spark
    Well i finally narrowed it down to pulling out the plug and looking for spark, and there is none, new plug, none so i got a problem somewhere else, where could it be?
    Confused As A Hungry Baby In A Topless Bar!!!
    '04 Honda CRF250R
    '82 Honda 200 4'sale soon
    '90 and '91 Arctic Cat Prowler 440
    '81 Kawasaki LTD 440 Belt Drive!!
    '92 Yamaha Warrior 350
    '05 DS 90
    Helmet save'd my friend's life, and mine, wear one!!!
    Trying is the first step to failure
    3ww Needs an iPhone app
    Duluth MN
    803
    No spark
    Well i finally narrowed it down to pulling out the plug and looking for spark, and there is none, new plug, none so i got a problem somewhere else, where could it be? its the '83 so it has a batt. in it and it seemes to be charged all the time.
    '04 Honda CRF250R
    '05 DS 90
    Pa.'s Highest City
    8,058
    Check all your connections on your harness. Make sure you have nice clean grounds. also, I seen this a thousand times on this site... If it's a honda 200cc most likely your stator. Seems to be a big issue with the honda's. Not that I'm bashing them or anything.
    May 2005
    B.S. Nebraska
    27
    I just got mine running and just my opinion, but on mine it was the coil. stator was good, but there was no resistance in the coil. just my two cents worth
    Pain is only weakness leaving the body!!
    1983 Honda ATC 200e "Big Red"
    1985 Honda 250 SX
    Duluth MN
    803
    stator? is that the little black box runing to my plug?
    '04 Honda CRF250R
    '05 DS 90
    Pa.'s Highest City
    8,058
    Your stator is down by the flywheel. I believe the left-hand side of the motor inside the case. It may very well be your coil for the plug. but nine out of ten times I think it's going to be the stator. I got a new one cheap at www.hyperparts.com. I would try this only after I checked all connections and grounds. also try a new plug gapped properly. Try the obvious before you panic. A multi-meter would help you out tremendsously.
