Results 16 to 30 of 31
Thread: CR500 compression release
    May 2003
    Houston, Texas
    2,409
    It will out accelerate a full size 500. From what I have seen where a CR or KX 500 need 1st or 2nd to make it up hills this bike can go in 3rd.
    Yes, its very impressive. The back end will get squirely on dry, grooved pavement if you accelerate the beast in 3rd.
    Plenty fast but it needs to be geared up a bit.
    (keep the classifieds in the classifieds section please)
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    Aug 2004
    Ab Canada
    4,368
    You COULD get a 91 or newer cr500 piston for it, they have compression relife cuts into the piston..make it nicer to kick over....but even without on stock comp its not hard to get er going....but shaved thats a whole nother ball park....
    1985 Tri-Z-
    Nov 2002
    hinesville ga.
    200
    on my atc 500 i had the head shaved and the cylinder base cut [shaved] to.it would take me about 25 or more kicks to crank it. right now i have 3 head gaskets and a unmilled head. now it takes about 10 kicks to crank it...so Derrick after you get this done to your cylinder PLEASE inform us...i called CT Racing and they told me that they drill 2 holes somewhere near the exhaust port and that releases some of the compression but when it starts the compression goes back to normal.and it only cost $45.00 plus shipping...
    Nov 2004
    Waterloo IL
    2,701
    My buddy just bought an 87 CR500. When I ride that I wear boots and I really have to jump to get it to start, I weigh about 180. I have a bunch of 4-stroke 500's but they have compression releases.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    May 2004
    Huffman, TX
    114
    believe it or not i was thinkin bout doin the atc 500R project my self,when are you gonna start?
    Mar 2003
    West Monroe, LA
    847
    Hey Tim, (250Rfanatic85) I found a full rolling chassis 250R, a guy brought it by the shop, it in real good shape. He also has a CR500 dirtbike, I went buy his house to look at it and the front forks are toast and it has no tires or wheels but it runs, it about broke my foot trying to crank it. He said it had a wiseco piston and shaved head. Trying to get a package deal, I'll let you know what happens.
    86Honda250R
    85Honda250R Sold
    82Honda250R
    Tiger 200 198? Sold
    Tiger 250 198?
    Tiger 80 (need engine) Sold
    85 Tri-Z
    86 Tecate
    Perfection consists not in doing extraordinary things, but in doing ordinary things extraordinarily well.
    Nov 2002
    hinesville ga.
    200
    Quote Originally Posted by Blown 331
    i went to wal-mart and bought some boots to crank it..it helps a great deal.....
    Mar 2004
    North Central Ohio!!
    2,712
    Well, I kicked on mine for 45 minutes today and couldn't get it started. I'm pulling the motor this week to get that decompression kit installed. I'll let you guys know how it goes. I'll have to call them monday and see what the turn around time is.
    Aug 2004
    Ab Canada
    4,368
    Just a tip for the Cr500 owners, for easy starting ( 1 kick if the bike is tuned right) befor you start it put it in second gear, rock it back n forth so the piston repedily go's from BDC to TDC about 6 or 7 times, this gets everything lubed up and draws the gas into the crank case, in fact this will work with any 2 stroke but works nice with the 500 for lack of havin to kick it 3 times.......First kick everytime if the carb is tuned properly...works like a charm
    1985 Tri-Z-
    Nov 2002
    hinesville ga.
    200
    on my atc 500 i have to slowly kick it to the foot peg,then pump it 2 times then kick the stew out of it...the second go round usually does the trick....
    Billy Golightly's Avatar
    Live Oak, FL
    15,068
    on mine, I just turn the choke on, make sure I dont give it any throttle, and then kick it as hard and as fas as I can with the tip of my boot. If it doesn't start in about 5-10 kicks, then I turn the choke off and hold the throttle wide open. If that doesn't get it to crank, I go back to the choke and repeat as necessary.
    Jun 2004
    geraldton, west australia
    1,068
    all in all these 500's sound like a c*** to start
    LIVELOVERIDEDIE
    1981 Honda Atc 124R-Racer project
    2005 Giant STP 1- rollin' on 26's
    Aug 2004
    Ab Canada
    4,368
    Quote Originally Posted by TrikerR
    Thats becuse there all ill tuned.....my buddys starts first or second kick everytime and it isnt hard ether with stock compression......
    1985 Tri-Z-
    Mar 2004
    2,712
    What year is your buddy's 500?
  15. #30
    Aug 2004
    Ab Canada
    4,368
    Quote Originally Posted by Derrick Adams
    91, but i have riddin the older one's too and kicked them over with the same ease........
    1985 Tri-Z-
