Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Thread: WTF! is up with fork seals!!!
    Las Vegas, NV.
    2,538
    I got mine quite a few years back from the Honda dealer. The replacement process is in the manual, but just looking at them, it's pretty evident how to remove & replace them. It's a lot easier than the seal replacement that you've already done!
    250rAL is offline Just Too Addicted Arm chair racerJust too addicted
    Sabula,IA
    620
    Quote Originally Posted by Huffa
    I don't think ATF will make them leak any quicker at all. Neither of us have any scientific proof that it does or does not. I'm sure Honda though would not recomend for years and years in the manuals to use the stuff if that was the case.
    Fork oil has additives to keep the seals soft; ATF doesn't.
    __________________
    '85 ATC250R
    .030 Over Wiseco
    FMF Pipe/Answer silencer
    36PJ Keihin
    K&N
    Boyesen reeds
    Magura hydraulic clutch
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
    Three Wheelin' Since '84
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by 250rAL
    I have a bottle of Valvoline Max life ATF which is for older transmissions and right on the bottle it says " Conditions transmission seals to prevent leaks"
    Even the normal stuff which doesn't mention about seals I'm sure they have the some type of additives in.
    I'd recommend the Max life for sure. A lot cheaper.
    Check it out : http://www.valvoline.com/pages/produ....asp?product=6
    Sabula,IA
    620
    OK, may be so. The old Type F I used years ago didn't do my seals any good and I'd rather not take the chance myself. If you want to try a different weight oil, you're out of luck with ATF though. If I remember correctly ATF is either 5 or 7.5 weight. I run 10.
    __________________
    '85 ATC250R
    .030 Over Wiseco
    36PJ Keihin
    K&N
    Boyesen reeds
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
