I Need A Way To Find Out What Is Bent In The Front End Of My 84 250r It Took A Hard Hit Into A Ditch By The Previouse Owner Then Sold To Me It Pulla Hard To The Right. The Trike Looks Like It Is Sitting Straight I Dont Know Where To Look.
Check the axle/rear tire pressures and if thats ok then just look around to see where it is bent
-Mike
Usually you will see whats bent, thats the only way of knowing. I would probly say the front forks are angled a bit, maybe one shock has less oil then the other.
1984 Honda 200es Big Red
Bored out
Aftermarket Exhaust
K&N Air Filter
Unfortunetally Blew the engine and got in a bad accident![]()
1984 Honda 200e/200es pieced together (parts machine)
1984 Honda TRX200 Works, but also needs work
