what's is the 1985 250R Transmission Oil Capacity and what brand would you recommend??
TIA
TIA
just shy of 1 qt.. 85 weight, semi syn fluid..,
Ride it like you stole it! And never look back! They are too far behind to see!
I dont have the spec in front of me but I think its slightly more than a quart.Remove the oil check screw on the side case until oil drips out of the hole. I recommend "BEL-RAY GEAR SAVER SAE 80". I used to run 10w-40, but have switched to the BEL_RAY and noticed a big difference. GREG
1985 ATC 250R
2006 TRX450ER
RIDE RED...IS THERE ANYTHING ELSE??????????
thanks alot![]()
Without going out to the shop to get the manual, I thinks it's .79 Qts.
__________________
'85 ATC250R
.030 Over Wiseco
FMF Pipe/Answer silencer
36PJ Keihin
K&N
Boyesen reeds
Magura hydraulic clutch
Roost Boost
MSR bars
OMF swingarm skid
ITP Beadlocks
Three Wheelin' Since '84
80 weight ?.. huh ? am i missing something here ?
Currently :
84 125 M - The Mini-SXnot running yet. but won't be long.
Its only a transmission oil, it doesnt lubricate anything else so they normally use a heavier (sp?) oil instead of just 10-30 motor oilOriginally Posted by bigredhead
1985 Honda ATC 350X
2003 Yamaha Banshee
2003 Polaris Sportsman 500
There are 3 kinds of people in this world, Those who make things happen, those who watch things happen and those who wonder what the hell happend.
son-of-a-gon.. learn sonthin new everyday here... 80w oil in an R tranny.. wow.
Those sucker use Dry or Wet clutches ?
Currently :
Its a wet clutch system. I am about to have to put a clutch in the 86R now.
1985 Honda ATC 350X
2003 Yamaha Banshee
Motorcycle/ATV 2 stroke gearbox oils are rated differently than standard motor oils. Their 80w or 85w weight pours like a 10w40. They work fine as do standard 10w30 or 10w40 motor oils. If you pour standard 90w automotive gear lube in there, your clutch will never let go when you pull it.
It takes a little less than a quart.
Ahhhhh.. now that's the part i never knew about.. similar viscosity.. just different rating..
I was picturing myself TRYING to pour fresh 80w hypoid oil in my SX's rear end last winter.. took me 5 minutes to get a damn oz out
Currently :
I Use 50wt. KENDAL or Valvoline Racing in my "Z".... I Was Told ( Many Moon's Ago ) ...NOT To use a Multigrade Oil in a ATV or MotorCycle.. i allway's used 20-50 Castrol ...But Since i Change to Kendal 50wt. Racing ....NO PROBLEM'S With My Bottom End !! GOOD LUCK !!!
"07" DR650 Suzuki Dual Sport
