Thread: tri-z coolant questions
    May 2004
    colorado and new york
    82
    there are 2 small tubes that go down into the neck and after riding for a while they start leaking coolant down all over my back of my front wheel fender. what causes this?
    Power_Ram100's Avatar
    Power_Ram100 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2004
    Kent, Washington
    152
    I cut mine so the hoses drain on the ground by the swingarm. I guess a full overflow bottle would cause your problem.
    I just thought of something funny...your mother
    83 Big Red with Bear Claws (SOLD)
    85 Tri Z with Maxxis Alltrax rear tires on .190 aluminum rims, DG pipe, Answer SA Pro silencer, High Flow Fuel Pump, and UNI air filter (SOLD)
    99 Yamaha Kodiak 400 4x4 with Warn winch and custom skidplates
    85 Honda 250 SX with Dirt Devils (near mint) (SOLD)
    Rittman, Ohio
    6,276
    Its the first place it spits coolant out when it overheats. Occassional spurts are not unusual, but if it does it a lot, the most common cause is the plastic impeller head coming off the shaft giving you no coolant flow.
    May 2004
    82
    can you still get a tri-z water pump? i should put a new one in.
