Results 1 to 10 of 10
Thread: Back to life! Tri Z pics.
    Nov 2004
    Wareham, Ma.
    13
    Finally got her back together.
    Attached Thumbnails Attached Thumbnails tri z #1.jpg   tri z #2.jpg   tri z #3.jpg
    Brandon, Manitoba
    2,209
    That looks great. Where did you get that FMF silencer? Ive been looking for one to put on my '85
    Brandon, Manitoba
    2,209
    Are those 10" tires? What kind of rubber?
    It looks pretty sweet
    NY
    3,185
    Super nice 86 Z. I may have something you want I'll pm you
    Nov 2004
    Wareham, Ma.
    13
    thanks guy's.
    The tires are 20x11x9 Trail claws, I had to modify them, a little. They were a ***** to slide, so I cut the side lugs off.
    The silencer is actually an Answer S/A Pro, I believe. When I bought the trike used back in '86, it had a kit from White brothers, which included an oversized Mikuni flatslide and a White Brothers pipe and silencer, anyways I replaced the silencer awhile ago.
    So, yesterday was a busy day. I mounted the forks (had the rebuilt with progressive springs), put the motor back in (new crank, rod, bearings,piston, clutch etc.). Then I started breaking her in. In between heat cycles, I mounted the new chain and sprockets. Finally, after getting her all buttoned up i took her for a easy ride. Damn, I missed this thing. Today I got to ride her a little harder, and what a difference a good suspension makes (Works Performance shock, Progressive Suspension springs)!
    I was real close to parting it out . I'm sure glad I didn't.
    Brandon, Manitoba
    2,209
    So, where did you pick the pipe up at?
    Nov 2004
    Wareham, Ma.
    13
    Quote Originally Posted by Yamahauler
    The pipe is White Bros. They used to sell them back in the late 80's early 90's. The pipe and carb where on the Z when i bought it from the original owner back in '86. He told me about carb pipe kit he installed, and I did a little research and found the pipe and carb kit in the White Bros. catalog.
    Watertown, New York 13601
    3,382
    looks good!
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    Ontario, CANADA
    4,538
    Looks real good!
    How much did you pay for your works shock? and your progressive suspension?
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Nov 2004
    Wareham, Ma.
    13
    Here ya go
    Springs
    http://www.denniskirk.com/jsp/produc...in&mmyId=13702
    I believe the shock was around $250, but I could be wrong? I bought it about 3 yrs ago. Give them a call. They ask your weight and what kind of riding you'll be doing.
    http://www.worksperformance.com/html...dstar_rez.html
