Hi all...great site! I just picked up a "hybrid" ATC90 that I'd like to get running. The frame says US90, the engine says US90E, but the seat and fenders are from a '78, and it has a headlight, which I don't think the older ones had, and the carb has the altitude compensator, which is older model. Hence the term "hybrid". Assuming that it ran at one time, but does not currently, I bought it for next to nothing and began working to get it going again.
Cleaned the gas tank and carb. New fuel lines and installed filters (tank is rusty). Replaced plug and points. Has spark, but won't start. Ran compression test. 60lbs. Not good. Checked valve clearance= ok. Squirting oil in the cylinder brings the compression up only very slightly. So I'm expecting to have to do a top-end rebuild. I've never done anything like this, and I have a few questions:
1. Does this sound like the likely problem? Is it usually valves causing it, or a leaking gasket somewhere?
2. Are the parts still available? I'dl love to find a top end rebuild kit somewhere, if such a thing exists. I need to call Honda with the engine code to find out exactly what year it is, before I start trying to order parts.
3. Can joe sixpack (that would be me) do a job like this if he has no experience but a little mechanical ability, and a Clymer manual?
Thanks in advance for your input.
