Results 1 to 9 of 9
Thread: Boyesen rad valve for 250r
    May 2002
    Cortland, NY
    1,195
    How do you guys like the boyesen rad valve in your 250r's? I noticed that the reed block and intake track are all once piece, is it the same lenght as the stocker or have you had to use a reed spacer to make it line up?
    http://photos.yahoo.com/dynofox250 (TF 03 pic's)
    Trikes: Restored '86 ATC 250r, original and mint '83 185s
    Quad: '86 TRX 250r
    Sled: Rev X 800ho mod
    Bike: '00 ZRX 1100
    TF '03 and '05 Survivor
    3leggeddog's Avatar
    Nov 2004
    well the intake tube on the rad valve is a little longer plus you get the rubber to adapt the carb to the rad valve,it should bolt right up.go with the v force setup though,it rips
    Jun 2003
    englishtown NJ
    2,676
    get the rad valve for a 86-98 cr 250r if you are gonna use a bigger carb, the low end is incredible with that rad valve. v-force reeds are mid to top end, boysteen are low to mid. I'd get a rad valve myself.
    May 2002
    Cortland, NY
    1,195
    Quote Originally Posted by deathman53
    The CR boot is shorter isn't it? I'd need a reed spacer to be able to use the stock air box tube correct?
    Quad: '86 TRX 250r
    Bike: '00 ZRX 1100
    Phoenix, AZ.
    6,719
    The dude at the local shop told me the CR one is identical to the regular 250R one except the angle of the intake is different and it comes with the bigger boot. If you run a bigger carb you can just get the bigger boot. They're interchangable. I bought one for like 7 bucks or something.
    3leggeddog's Avatar
    Nov 2004
    i don't think the angle is any differrent.when i had the entire cr motor in my 86r the carb and boots all lined up.i don't think you will need a spacer.are you running a bigger carb?
    Mar 2003
    West Monroe, LA
    847
    I have the radvalve on my 86R and highly recommend it. I noticed more snap off the bottom and also better acceleration all the way through the mid range. even seems to idle better.
    86Honda250R
    85Honda250R Sold
    82Honda250R
    Tiger 200 198? Sold
    Tiger 250 198?
    Tiger 80 (need engine) Sold
    85 Tri-Z
    86 Tecate
    Perfection consists not in doing extraordinary things, but in doing ordinary things extraordinarily well.
    Jun 2004
    Oregon
    1,784
    I just installed a 38 airstryker with a rad valve on my 85R and it flat out hauls asssssssssssssssssss....
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
    Jun 2003
    englishtown NJ
    2,676
    I had to put a reed spacer on my bike, but also I'm using a aftermarket cylinder.
