Results 1 to 13 of 13
Thread: CDI Limits Revs?
    canada
    77
    CDI Limits Revs?
    Does my 200es have a rev limiter?? I was told the CDI limits the revs. ??
    1984 Honda 200es Big Red
    Bored out
    Aftermarket Exhaust
    K&N Air Filter
    Unfortunetally Blew the engine and got in a bad accident
    1984 Honda 200e/200es pieced together (parts machine)
    1984 Honda TRX200 Works, but also needs work
    Opelousas, Louisiana
    1,337
    i dont think so.
    1986 350X K&N filter, DG Krome Power exhaust
    1982 110 UNI filter, Cobra megaphone exhaust
    1982 honda 110 exhaust for sale, PM me.
    canada
    77
    ok, I didnt so either, but wanted to make sure.
    Bored out
    Aftermarket Exhaust
    K&N Air Filter
    springville, PA
    6,185
    I was told it did.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    canada
    77
    now I'm in the middle again
    Bored out
    Aftermarket Exhaust
    K&N Air Filter
    Jan 2005
    Michigan
    135
    but told by who ?
    i dont think so seeing dirt bikes didnt that i known of(they use same basic engines)
    and how many times have you seen or been told that someone over reved a bike and hurt the engine
    85 200X
    4" supertrapp
    66MM 12:1
    82 Big Red
    85 Tri-zinger
    Jul 2004
    Mud hill. close to water !
    3,658
    You can over rev a honda 200 cc motor ?.... wow. !!!!!
    lol. seriously tho.. i think you are limited by the sophistication of the engine... the rotor/timing advance unit can only do so much, the poor thing will rev it's heart out on a down hill in 5th with wind at your back to the point of vibrating itself silly..... ( i know. i've done it !! ) but if they built in a rev limiter.. it should have kicked in before that....
    Currently :
    Im unsure about your model but the 250SX definately has a rev limiter to stop them from breaking cranks as they had done before it was a service bulletin. They may all have rev limiters....
    springville, PA
    6,185
    I was told this by my uncle who repairs ATVs for a hobby. He might have been pulling my leg since he told me a 2 stroke's gas oil mixture goes through the crankcase to the carb, and that there is no oil in the crankcase like a 4 stroke
    Nate
    R.I.P HRR
    Jul 2004
    3,658
    on 2 strokes.. gas goes from carb to crank to cylinder.
    no oil needed on no tranny engines.
    Currently :
    springville, PA
    6,185
    Quote Originally Posted by bigredhead
    So two strokes have oil and gas in the crankcase?
    Nate
    R.I.P HRR
    Brandon, Manitoba
    2,209
    No, you put 4 cycle motor oil in the crankcase/transmission
    Jul 2004
    3,658
    Yep.
    That's why you need to mix the gas.. the crank gets it's lubrication from the oil in the mix.
    The crank and the Tranny are seperate.
    Currently :
