another trike and quad will be in my near future.
I just won a cherry frame for my atc350x project on ebay. I got a front end ready to go, pipe, motor, pegs, and almost everything I need, except the rear end parts. I'm gonna use a 350x carrier, 300ex axle, 3.5mm shaved off a 250r brake hub, 250r rear brake, 400ex hubs and also can't forget I'm gonna use 86/87 250r roll design kickup pegs on the 350x peg plates(they fit on all 350x's, 86 atc2505, 86/87 200x).
I also have a 88 250r frame, getting a +3 long travel front end, have a elka shock(ordering another, as the shock is currently on my atc250r), elka front shocks, hyper front beadlocks, 86/87 spindles and hubs, lsr axle, carrier and antifade. I'm not sure what I'm gonna do with final rear tires, igniton, and motor. I'm gonna put in a hacked up 85 250r cdi in(totally stripped down to bare essectails), 88 bottom end and ported cylinder, stock carb, stock intake. The important part to me is the chassis, next year I will worry about modding the motor(and NO the lrd 310pv on my atc250r is NOT coming off the trike, nor is the cr igntion, 38 a/s, cr rad valve). this will make a 86 atc250r(very modded), 03 crf488 quad(even more modded), 01 xr 250r(street legal and modded), 86 200x(84r front end, works shock, 350x supertrapp, roll pegs, +4 axle, 27mm carb, ported/polished motor) I'm also having a 86 atc250r frame out for pc, not sure what I'm doing with that yet.
//ArrowChat Integreation Code
