Results 1 to 8 of 8
Thread: ? about compression on tri moto 175
    3leggeddog's Avatar
    Nov 2004
    how much compression do those have,i can roll mine right over with out a pull starter,bare handed.has a little resistence but not much.
    Ithaca, NY
    2,596
    mines got a Ton, and it eats pull ropes because of it! I go through a pull rope every couple months, and I dont ride it much, if ever.
    Haspin veteran '02, '03, '04, '05
    "Hey is your dash-cam on? Are we gonna be on C.O.P.S?"
    RECOVERING Trikeaholic
    Jul 2004
    Mud hill. close to water !
    3,658
    Quote Originally Posted by Trikeaholic
    something is cutting into it or rubbing hard.
    open it up get the sand paper or dremmel and smooth all the cable passways etc.. smooth out any sharp pieces.
    Pulling hard on a rope should not be a problem.. friction however !!!!
    How much PSI you got now ? i know a 200 honda 4 stroke has aprox 140 - 160 when fresh.
    Currently :
    Jul 2004
    3,658
    check the homepage under " Specifications " .. might be listed.
    Currently :
    3leggeddog's Avatar
    Nov 2004
    could the lack of compression be due to the fact the carb slide is missing?thanks
    Jul 2004
    3,658
    no.
    the slide ( or carb for that matter ) has nothing to do with compression.
    Currently :
    Nov 2002
    Kirkville, NY
    3,831
    The book says 128psi for the YT175. If you can spin it over that easy then something is wrong. Missing the carb. slide should affect the compression but in a good way. For a compression test you are supposed to hold the throttle open so it can get as much air as possible, without the slide the throttle is already open.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    3leggeddog's Avatar
    Nov 2004
    thanks guys,i need to tear into it,do a compreesion test and get this thing runnin.
