Results 16 to 30 of 56
Thread: 250R crapping out on topend
    Jun 2004
    Oregon
    1,784
    38 a/s ,radvalve,ported,no airbox bored .10 40-1 hp2 with 110 racing fuel,eunning a br9es...pilot is 55,mail is 178 needle is 2 slot.
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
    Jun 2004
    Oregon
    1,784
    Quote Originally Posted by 3leggeddog
    your air screw will have nothing to do with top end.your rich on the main drop to a 170-172.if your gonna jet go atleast 1 size at a time.thats two jets lower,would equal i size,the others are half sizes.it's breaking up at full throttle right?
    Yes when i pin the thottle its crapping out..
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
    Jun 2004
    AZ
    43
    Any compression mods ie thinner head jasket,cut cylinder head. etc i realize this is not the direction you where going but im wondering about the 110 octane to me it sounds like wasted money but hey, as far as the other question id keep going down in jet size, sounds like its fat to me, what altitude are you at. The other question is was it running good with the other carb might be an ignition problem but id bet its just fat.
    Jun 2003
    englishtown NJ
    2,676
    well, low end reeds and a top end pipe are gonna be part of the problem, but not enough to make that much of a difference, it sounds as it has port work done to it. A low end pipe would help, if thats what you want.
    May 2005
    Fort Worth,Texas (watauga)
    112
    sounds like the same thing mine does,and i`m clueless,lol......don`t know squat about messin with jets and all
    trikes owned:
    1982 ATC 185S
    1983 ATC 185S
    (2) 1984 ATC 185S
    1984 ATC 200M
    (2) 1984 ATC 200S
    (3) 1984 ATC 200X
    made one an auto-x,easy swap
    1985 ATC 250R (stolen!...the bastards!...it was mint!)
    own now:
    1985 ATC 250R (running)
    1986 ATC 250R(parts bike)
    1984 ATC 250r w/ 280cc kit in it(pretty rough-needs TLC)
    1984 ATC 200s (running)
    1982 ATC 185s (running)
    (2)1984 ATC 200s(parts)
    1984 ATC 70 (parts)
    1983 ATC 70(off ebay-running)
    1985 ATC 70 (running)
    198? ATC 70 (running)
    1984 ATC 200x (running)(have made it an auto-x until i rebuild the top end of the X motor)
    1985 ATC 200x roller(gonna make another auto-x)
    Eric
    Phoenix, AZ.
    6,719
    This ain't that complicated. It's too rich. Dark brown is too rich. Sputtering at WOT is too rich. It isn't the rad valve or anything else. Go down to about a 172 and if the problem isn't gone it's gonna be much better and you'll have a better idea of what's going on. Check the plug and go from there.
    Edit: that 55 pilot is probably richer than it needs to be too. If it's not snapping off idle real good lean that out as well. Is the needle in the 2nd position from the top or the bottom?
    Jun 2004
    Oregon
    1,784
    Quote Originally Posted by Dammit!
    From the top............I just went to honda and got a 172 main and a 52 slow...Lets see what happens now :
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
    wanta86r's Avatar
    wanta86r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2004
    mn
    385
    make sure you only change one jet at a time. dont do both changes at once
    Jun 2004
    Oregon
    1,784
    yeah ill make sure i do that....THanks man
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
    3leggeddog's Avatar
    Nov 2004
    jet er down bud and things will be fine.drop a 172 in there and do the plug chop like i told ya.report back after that.
    Jun 2004
    Oregon
    1,784
    Well, i put a 172 in and 2 turns out on the air screw and running a br8es...My plugs are coming out light tan and its stopped spuddering on the topend..i rode a wheelie from 1st to 5th down my street till i ran out of room, otherwise i could of hit 6th lol..So i guess its running good now..The only prob is when i pull the choke it still runs the same...Im not sure if this is a big deal but it starts 2nd kick everytime and when i let off the gas it comes down to a perfect idle..I think its running a litte rich but that ok with me....Thanks for all the feedback on this! you guys really helped me out.................
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
    May 2005
    112
    yea,i was running the stock 142 in mine and went and picked up a 140 and a 138 today at Honda....put the 140 in and it seems to be running better now....i just wouldn`t know how to tune this thing right if my life depended on it,LOL
    trikes owned:
    1982 ATC 185S
    1983 ATC 185S
    (2) 1984 ATC 185S
    1984 ATC 200M
    (2) 1984 ATC 200S
    (3) 1984 ATC 200X
    own now:
    1984 ATC 70 (parts)
    Eric
    Jun 2004
    Oregon
    1,784
    well its not to tough if you read your plugs...I was having probs trying to get this stryker tuned..I listened to the guys at honda witch proved to be a HUGE mistake..Just post what your trying to do to your R and these guys out here will get you on the right track...They did me!!
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
    3leggeddog's Avatar
    Nov 2004
    glad we could help bro,shoot me your carb troubles anytime,sometimes i may help,other times i may not.
  15. #30
    Jun 2004
    Oregon
    1,784
    Well i finally got to take my R to a wide open space and open it up..Low and behold its still doing the sput sput sput at the topend..Its running much much better then what it was ,but i was wondering could i drop another size to a 170? or just leave it as it is and see if it might clear out after a few runs...THANKS!!
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
