It is really hard to pull the clutch in on the Tri-Z. The clutch wasn't disengaging a while ago, but I almost fixed it yesterday, it was a worn out linkage shaft, the push lever also had some wear.
I replaced those with a spare one I had, and now it will push the pressure plate out, but it still drags when you put it in first, hold the clutch and try to push it.
What could have caused it to wear out that shaft so fast? The point on it is completly worn down. The clutch pull became very hard and then it just stopped working and wouldnt disengage.
