Results 1 to 9 of 9
Thread: I need some electrical know-how
    Brandon, Manitoba
    2,209
    I got my handwarmers today and I know how to install them, all except for which wire to tap in to in the headlight to get a 12-volt regulated circuit. If anyone could tell me, that would be great.
    Thanks
    Heres the wiring diagram for my trike.
    http://www.files.3wheelerworld.com/W...YTM200EKEL.jpg
    Heres the wiring diagram for the handwarmers.
    Mar 2005
    ma
    988
    why can't you run a wire right from the battery? if you go from the headlight won't you need to have the headlight on to run the hand warmers? unless thats what you want.
    Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
    Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
    My Feedback
    http://www.3wheelerworld.com/showthr...k-for-sblt500r
    springville, PA
    6,185
    taking it to your head lights is alot of hassel you dont want. Run them to your battery and it is so much easier.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    oddball3's Avatar
    oddball3 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2004
    New Jersey
    224
    I wouldnt hook it directly to the battery, because if you leave the hand warmer switch on you will kill the battery. My Dad had his hooked to the batt and always had to remember to shut the switch of after riding.
    I would hook it to one of the blue low beem wire, or another hot wire while the trike is running. Not to a constant hot. Or you might forget to shut the switch off and it will kill your battery.
    IN MY GARAGE:
    1984 250r
    1986 350x
    1986 200x(wifes)
    1985 200x fixer upper
    1979 110 PARTING OUT
    1984 70
    http://www.hardcoresledder.com/forum...post&id=155447
    '97 ZRT 600 drag sled
    '97 ZRT 600 trail sled
    '98 ZR 440 sno-pro(wifes)
    http://www.hardcoresledder.com/forum...=post&id=79401
    springville, PA
    6,185
    Quote Originally Posted by oddball3
    I wouldnt hook it directly to the battery, because if you leave the hand warmer switch on you will kill the battery..
    Yeah I've had that happen once or twice, but that is why you have a backup starter
    Nate
    R.I.P HRR
    Howdy's Avatar
    Celina, Ohio
    10,079
    You should be able to hook it up to the brown wire coming from the ignition switch ( it runs the neutral light. This would allow them to be on when the motor isn't running.
    But, I would reccomend hooking it up to the L/B ( I think it is Blue with Black stripe )wire that powers the lights. You want to be sure to connect it between the key switch and the light switch. Going this route would make it so that the machine has to be running for them to work. This would help you keep from draining the battery as fast. Going this route you would need to take the Red wire from the warmers and ground it to the frame, take the yellow wire and connect it to the L/B wire and you should be good to go.
    Howdy
    Brandon, Manitoba
    2,209
    Quote Originally Posted by Howdy
    Howdy
    That sounds good, thanks. But another question, is, will the lights have to be running for the warmers to work? Or will you be able to use the warmers without running the light.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by Yamahauler
    If you hook the yellow wire up to the BR wire coming from the key switch ( it should be on when the switch is on ), then you would be able to run the warmers when ever the key switch is on.
    Howdy
    Brandon, Manitoba
    2,209
    Well i got the handwarmers hooked up and, wow they are good.
    I tapped the Brown wire coming from the key switch and it will work on the second key position. I can't run it right now though (rebuilding top end)
    Thanks Howdy!
