YT60 carb
Hey gang,
Haven't posted in a while...been in hospital again. Glad to home but have found upon my return that the kids little 1984 YT60 is acting up and not wanting to idle or start easily. Here is what I have to done thus far to alleviate the problem but to no avail:
1.) Drained old gas from tank and carb.
2.) Cleaned and gapped spark plug and confirmed spark OK.
3.) Cleaned air box foam filter element. (This one IS foam) Maybe not OEM
4.) Adjusted both carb screws through every single combination of settings. (Lean/Rich/Lean/Rich)
5.) Pulled carb and checked float for leaks or holes (none found)
6.) Checked all needles including inlet valve under float for wear and/or contamination. (none found)
7.) Reassembled and problem persists
I am about at wits here and the kids are driving me nuts to fix it but I am at a loss. Got a Honda ATC70 complete restoration in the works but I need a decent head for that engine, so I am really in a jam. Could the YT60 problem be the fuel pump? Does anyone have a good Honda ATC70 head for sale? Either way could solve my problems!
Peace!!!
Life shouldn't be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather, to slide in sideways, thoroughly used up, totally worn out, and loudly shouting...... "WOOOO HAAAA WHAT A RIDE! THANK YOU LORD!!!"
