i made these at work the other day.they are made from alum than polished i made them on a cnc mill.with these on the trike sits alot higher 12.5 inch under the foot pegs. i set it so that it sits just a little bit higher in the rear then when you sit on it it levels out. seems to work great im not sure if any one has done this.i wanted to utilize the 200x rear shock instead of the 350x change over only because i could not afford the parts right now.i do want the 350x front end for my x .also i need a new front tire it has a 23.5 on it right now can i go bigger on the height or should i stay the same. i am running 20's in the rear on 9' inch reams. what do you think would be the best tire set up
That has the makings for a sweet little kit to through on ebay.
