Results 1 to 15 of 17
Thread: ytm update
    nimda78's Avatar
    nimda78 is offline At The Back Of The Pack Arm chair racerFirst time rider
    coeburn va
    177
    Cool ytm update
    yesterday i repaired my front and rear brakes to like new working order...just needed some cable lube and some grease applied to some of the components that friction affects. today i sanded and painted the header pipe, and changed the handle bars to a set of 2"rise steel kx80 bars. feels great!
    Attached Thumbnails Attached Thumbnails dirt toys2 001.jpg   dirt toys2 003.jpg   dirt toys2 004.jpg
    -1983 Yamaha YTM200K chain drive -3rd owner! -UNI dry foam performance filter /w wet outterwear -RM 125 2" rise steel handle bars in black powder now - bent from a rolloverCustom 2" round LED tail light /w stainless steel trim in aluminum mount Custom polished aluminum diamond plate rear fender brace with Stainless steel hardwareStainless steel Torx mudflap bolts Custom ONAN vtwin muffler TOUGH sound
    -1986 kx80- S O L D
    toyota200x's Avatar
    toyota200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2003
    402
    Pretty original but maybe a little to jazzy for my taste. Is there any reason that you have the forks slid up in the tubes?
    Owner of
    '98 klx 300r
    '85 250sx
    '82 185s
    nimda78's Avatar
    coeburn va
    177
    im not sure the frame came factory red, but i like it. and it was done well, and the right way. i didnt have enough high temp matte black to do the header today, so the dark graphite was close enough. the forks came to me like that. i dont plan on moving tme up, i like the droop in the front for COG purposes.
    -1986 kx80- S O L D
    Brandon, Manitoba
    2,209
    The red frame wouldn't be factory, all YTM's only came with black frames. Someone must of done it theirself. It doesnt look bad either.
    Jan 2005
    Slatington PA
    4,372
    A little advise to help your trike look much better and this of course is just my opinion.
    Take all the paint off the nuts and bolts and gas cap etc,etc etc. It just looks so gaudy like that and it's a sure bet some young kid did it. Maybe even you did it but really, that makes the trike look terrible.
    In seconds with a bench wheel or a wire wheel on drill you can get it off the nuts and bolts or do you actually like that?
    If you do like it, hey thats fine but some day you'll grow out of that and ask yourself "what on earth was I thinking?
    nimda78's Avatar
    coeburn va
    177
    nah i agree 100% im 27, and i do think the red "detail" work is gawdy. the kid i scored it from did all that. ill keep the red frame, cause i think that is cool. but a freash coat of gloss black is in order for the engine case for sure! thanx again!
    -1986 kx80- S O L D
    nimda78's Avatar
    coeburn va
    177
    i was thinking, the engine already has atleast one factory coat and at least one spraycan coat of paint on it as it sits...should i spray the engine with easy off oven cleaner to break up the walmart paint this guy had put on the cooling fins, or would a freash coat over whats there be ok?
    -1986 kx80- S O L D
    nimda78's Avatar
    coeburn va
    177
    Quote Originally Posted by Huffa
    i did ask the kid that did it wtf he was thinking....LMAO
    -1986 kx80- S O L D
    springville, PA
    6,185
    I think that thing looks cooler than ****! I like the red frame and axle along with the red on the engine. Between that and the yellow I think it gives it a great color scheme. Nice looking bike.
    P.S. Destroy that seat cover. lol now that looks hidious.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by 250sxwheeliepop
    What red axle? All that I see is a red hub with of course the nut painted red and the valve stem painted silver. That kid went waaaaay overboard with the red.
    Take the red off tha cables for a start and that will be a big improvement for sure.
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by nimda78
    Well as long as the paint on there seems to be holding up I'd say just leave it be. What you want to do is use case paint I think or some kind of satin. You don't want the engine too shiny. Thing is, on that model, you don't see the engine very much anyway.
    Jan 2005
    Slatington PA
    4,372
    Stupid kid
    nimda78's Avatar
    coeburn va
    177
    even though the cable covers are abit over the top...they are keepin g the sun from damaging them..and thats always cool. i like the seat cover he had made for it..alittle wild, but a plain plack seat wouod look stock...and who likes stock machines?
    -1986 kx80- S O L D
    nimda78's Avatar
    coeburn va
    177
    lets see your 300.00 collection of trikes huffa
    -1986 kx80- S O L D
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Looks like a rainbow after a thunder storm.
