Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Thread: 200x update
    Oswego, IL
    1,858
    the oil cooler is off an old water pump. my dad just had it sittin in the shop. so do you guys think fork boots will make it look any better or no boots? and will smaller tires get me more $$$ when i sell it.
    1974 atc 90 project underway cuzzztom
    1985 atc 110 for sale
    84 200s all original got off the first and only owner
    new carb
    maybe putting my 200x cam in it but not sure
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    Pa.'s Highest City
    8,058
    I think red boots would look sweet. I don't think 20" or 22" will make much of a diffrence in value of the trike. Although I think a set of 20" razors with the red lettering on the sidewall would look sweet on that machine.
    Oswego, IL
    1,858
    well today im going to work with the diff shock so then i can get the mount made right(first one was too beffey, strong, but to big). so ill be messin with that if i get something to work ill throw a pic up. i sent a pm about the tires the holeshots. (90nut)
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Oswego, IL
    1,858
    havin some trouble getting out the bushing on the top of the 250r shcok. its stuck in there good. its not really the bushing i need to get out it is some spacer. its to big for the 200x top shock mount. but if i get it out it will work. ah what the hell ill go snap a shot so maybe someone can give me a hand.
    here it is, i need to get that piece out. its in there good. i guess ill soak it in some lube and if i got to ill just cut it down. its tuff **** tho. dont know how i would cut it.
    this black bute is up for sale. found a bad ass car for a few grand and got to sell her. it will have the good rear shock on brfore i let her leave. let me know if you are interested.
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    LaDano is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    Denham Springs, La
    288
    I'm lost about the old water pump. How did you do it, And with what parts? Thanx
    '02 ranxher 4x4 '83 big red '84 110, '86trx70 project, '85 bigred project
    Oswego, IL
    1,858
    my bad. the cooler its self is for an old water pump. for the oil cooler you need to drill 3 holes in the side case, tapping into the oil track. first hole to lead to the oil coller. second is a block and 3 is so the oil comming from the cooler can get back in.
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Oswego, IL
    1,858
    here is a pic ill get a better one tomorrow.
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Maryland
    3,077
    The exhaust on that bike, i know it says supertapp but is that actaul 200x axhaust or off a dirtbike. I've often wondered is a XR200 exhaust could be modified to fit the 200X.
    Oswego, IL
    1,858
    no its for a 200x. its rusty tho. it was one of thoes ebay guys saying "light surface rust" well its pitted prertty bad im kinda pissed. o well.
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Mar 2003
    Denham Springs, La
    288
    If I keep it I'll be asking more details about the oil cooler. Thanx
    Oswego, IL
    1,858
    ok here are some pics to help out
    Attached Thumbnails Attached Thumbnails wheeler 024.jpg   wheeler 023.jpg   wheeler 022.jpg   wheeler 019.jpg   wheeler 020.jpg
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Oswego, IL
    1,858
    ok now with this pic number 3 is a port. after you put a fittin in here and have all of that done this one leads to the oil cooler. number 2 is going to be a plug in the oil passage way inside the cas. a block off bolt. then number 1 is for the line comming back from the coller so it puts the oil back in the motor. on the side case there is that little marking to the left (number 1) you can use that for a guide on where to put your number 1 fitting. then the plug should be about 1/2 inch over from that and then the other one(number 3) a 1/2 inch over from that. now the passage way you are tappin in to is in the other pic. (no numbers)
    ill doulbe check on the whole 1.2 inch thing. it sounds right tho.
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Mar 2003
    Denham Springs, La
    288
    Looks like I'm gonna keep the x, I wish I seen all of this 2 weeks ago when I put the motor back together. I'm gonna look into this a lot harder, thanx. By the way, how much cooler is it running?
