Results 1 to 9 of 9
Thread: sray paint for plastics
    new york
    5
    Question sray paint for plastics
    has any one used the kylon fusion paint for plastic?
    NY
    3,185
    Welcome!!
    http://www.3wheelerworldforums.com/s...t=Fusion+paint
    Some guys here have had some success
    oddball3's Avatar
    oddball3 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2004
    New Jersey
    224
    My brother sprayed his 300ex fenders white with the krylon fusion paint and so far its holding up pretty good. been through the mud, power washed, and no chips. It might chip getting hit with branches going through the woods and stuff. But his held out pretty good.
    IN MY GARAGE:
    1984 250r
    1986 350x
    1986 200x(wifes)
    1985 200x fixer upper
    1979 110 PARTING OUT
    1984 70
    http://www.hardcoresledder.com/forum...post&id=155447
    '97 ZRT 600 drag sled
    '97 ZRT 600 trail sled
    '98 ZR 440 sno-pro(wifes)
    http://www.hardcoresledder.com/forum...=post&id=79401
    Power_Ram100's Avatar
    Power_Ram100 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2004
    Kent, Washington
    152
    krylon fusion is what i use, havnt had any problems with it flaking off.
    I just thought of something funny...your mother
    83 Big Red with Bear Claws (SOLD)
    85 Tri Z with Maxxis Alltrax rear tires on .190 aluminum rims, DG pipe, Answer SA Pro silencer, High Flow Fuel Pump, and UNI air filter (SOLD)
    99 Yamaha Kodiak 400 4x4 with Warn winch and custom skidplates
    85 Honda 250 SX with Dirt Devils (near mint) (SOLD)
    arizona
    550
    i was thinking about painting my bike with the stuff too. do * need to do anything to the plastics or just sand and spray?
    oddball3's Avatar
    Apr 2004
    New Jersey
    224
    We just cleaned it good with rubbing alcohol, and rubbed it down with steel wool or a scotch bright pad. Then cleaned it again.
    IN MY GARAGE:
    1984 250r
    1986 350x
    1986 200x(wifes)
    1984 70
    Jul 2004
    Mud hill. close to water !
    3,658
    it should not flake off.. but hit a branch and it will obviously scratch eventually.
    I"m considering doing mine red.. so scratches won't be as noticable.
    Currently :
    Its not bad ive done a few bikes with it the only bike its not holding up good on is my lil z50
    1983 Honda 110
    1967 Mustang
    Jul 2004
    3,658
    It's all about the prep.
    everything needs to be clean as a whisle.. wiped down with solvent and a CLEAN rag or betteryet paper towel. and then don't put any oily finger prints on it before you paint.
    if you use a shop rag that has been in contact with grease or oil it will leave a film and paint will not stick properly.
    Currently :
