Results 1 to 9 of 9
Thread: Need some help...look at this carb
    BIGKAHUNA is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2002
    220
    I acquired this carb in a package deal of parts and was told that it is a 36mm Mikuni carb for an 85/86 250R. I was wanting to trade it for a 34mm stock carb so I posted it on the classifieds. I sent pics of the carb to someone and was told that it appears to be a dirtbike carb and not an ATV carb. Beings I dont have a lot of experience with carbs I figured I would draw from the well of knowledge on the board. I was under the impression that if it fit, meaning that the carb boot fit, the air box tube fit, the fuel inlet was on the correct side etc. that it would work. I guess my question is how does a dirtbike carb differ in design to an ATV carb and should I even consider using this carb...heres a pic.....
    Aug 2002
    New York
    1,098
    carbs
    They don't. The main concern is where the fuel inlet is. I have run different carbs on bikes and that is the only "issue" I have come across. The mm of the carbs and the jetting will change performance, but many carbs are interchangable. I run Kenin 39 PWK's on my bikes. The 39PWK gets used on all sorts of bikes, including racing Motorcycles. There are guys that run them on older model race bikes like CBR900RR's that were carburated. They also use them when they install a trubo on a lot of street bikes.
    If a carb can be used in that wide of a range, I'm sure that whether it's a "dirtbike" or "ATV" shouldn't matter. If they can graft a Pilot 400cc motor onto a 250R, a carb change is not an issue. A 2 stroke dirtbike and a 2 stroke ATV are very similar motors. I prefer Kehin over Mikuni (I have both) but both should work fine.
    If thats an atv carb theres a nice jet kit on ebay. Its a nice set. just a thought.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Nov 2002
    220
    Thanks for the info guys..and thanks for the heads up on the jet kit blazerone. So if I understand you correctly there are no differences in the design of the carb other than say jetting or other tuneables stuff? I was also told that it would not offer the same performance of an "ATV" carb....I am assuming this is not the case....this is good news..thanks again.
    Nov 2002
    220
    Quote Originally Posted by BLAZERONE22
    BLAZER could you link me up to that jet kit on ebay?
    Rittman, Ohio
    6,276
    I agree with ChrisD (nice to see you again!) Ill just add, probably even harder to work around is location of the choke. A lot of ATVs only have access to one side of the carb, and if choke is on the wrong side, life could be difficult.
    Nov 2002
    220
    Fuel inlet and choke are on the correct side!
    I'm farting around with my carb now If you type in munitki jet kit it should pop up. if not let me know and I'll find it for you. its huge
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    here's the link hurry it only has an hour left http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=34284&item=2401819 942&rd=1
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
