My 200s bogs just off idle and once its warmed up it idles poorly. I'm thinking the air screw needs adjusting but I dont' know which way to turn it.
1 1/2 to 2 turns out from turning all the way in is a good place to start.
1982 YT 125 Yamaha 1984 Honda 200 m
Could be an cracked intake boot, clogged jet(s), trash in the carb....etc. I'd check those first. if all those are good and you wanna mess with the air screw, get it idleing- fool with it, and see what it does. Trial and error kinda thing. Eliminate what it COULD be, and localize the problem before you guess too much.
1986 Honda ATC 200 S
Some quads and a S x S
Supporter of Uncle Rico's football camp. Since 1982.
If you are reading this in English, thank a U.S. Military VET. ΜΟΛΩΝ ΛΑΒΕ
And start with a CLEAN air filter. don't forget to oil it !
Currently :
84 125 M - The Mini-SXnot running yet. but won't be long.
hey laugh if * will but..... what octane * runnin in her. I had the same prob with my 90. but not only ideling poorly when warm but it would die totaly if * give it gas. My prob was when the motor was heated up and the head expands, the combustion chamber gets smaller.... upping the compression. If the octane is too low it won't run when it is up to temp. So check for that. also check timing, if your fireing too late * can get the same effect (also happened to my 90) so advance it a little if it is off.
hope I helped lol
I have one POS ATC 90 and that is it.
I have a 1971 Plymouth Duster on the way,
shes gettin a 360 under the hood![]()
I am new to 3wheelers but love them.
I am only 15 so don't expect much. LOL
Oh and I must give a special thanks to one person
that has helped with most of my problems
(My trike Sucks)
Although I am new to the fourm I like it much here!
ok all good ideas I'll check today, I'm just running regular gas in it now would supreme help?
