Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 62
Thread: Carb Experts Needed!
  1. #31
    Mar 2005
    ma
    988
    and those 2 things in your hand. one on the right is the main jet and the one on the left looks like # 18 on that diagram. you really don't have to change that. you pull out # 19 to get it out. push it down from the inside of the carb. it should fall out towards the bowl. but make sure it goes in the same way or it won't run right. thats where the needle goes in to.
    Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
    Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
    My Feedback
    http://www.3wheelerworld.com/showthr...k-for-sblt500r
  2. #32
    Pa.'s Highest City
    8,058
    Quote Originally Posted by sblt500r
    Sorry, but I had to add that attachment to your post. Makes it easier
  3. #33
    Mar 2005
    ma
    988
    it does but you can't really read that. i have the same manual in front of me.
    My Feedback
  4. #34
    Pa.'s Highest City
    8,058
    I think I'll figure it out. If not it's going on ebay and someone on these boards will send me a working carb!
  5. #35
    Mar 2005
    ma
    988
    i take it you've givin up on trying to get it to work?
    My Feedback
  6. #36
    Pa.'s Highest City
    8,058
    Well maybe just for today. lol
  7. #37
    Jun 2004
    Oregon
    1,784
    lol.............
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
  8. #38
    Old 179's Avatar
    Old 179 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Southwest Indiana
    300
    did you check float and float valve sounds like you didn't
  9. #39
    Fresno Ca
    2,695
    When you take out the float theres a little pointy thing that attches to it. Check that and make shure that the ruber on that isnt messed up. also make shure its in there correctly, Your problem is defently centered around the float.
  10. #40
    Pa.'s Highest City
    8,058
    These are to diffrent kinds of floats I got. Dads posted something on here somewhere about two diffrent numbers on the carb for the 200cc. I have both which should I use? Both float?
    Old 179 i didn't get a chance to do that yet my trike isn't at my house
  11. #41
    Jan 2005
    Slatington PA
    4,372
    Your having a heck of a time I see but you are learning.
    I guess I should really come up (like I keep saying )
    I'll check with the wife and see if Saturday is OK.
    Maybe you'll have it fixed by then though ?
  12. #42
    Pa.'s Highest City
    8,058
    Quote Originally Posted by Huffa
    Hey Gary... By Saturday I will be tanning on the beach!
    But yes I am determined to figure these things out. gotta learn sometimes right?
  13. #43
    Jul 2004
    Mud hill. close to water !
    3,658
    The orange plastic float is the same that i had on my 84 200 ES big red.
    the black float with metal tab was on my 82 200 .
    if that helps any.
    Currently :
  14. #44
    Jul 2004
    3,658
    see how you have it it your hand. over the spring put the steel washer then the o-ring then put it in the carb front hole and screw it in. just till it stops, don't over tighten it you'll screw it up. then unscrew it 1 1/2 turns. that gives you a ball park measurement. then you adjust it when its running.
    ^^^ This is correct,.
    Brass piece.. then spring. then metal flat washer and then ruber o-ring.. DO NOT Overtighten. or you will crush the o-ring.
    The other brass round thing you had in your hand ( without threads ) .. you need to pop the one on the carb out and put this one in it's place.. no threads.. just find something metal and round that fits and give it a tap it will come out.
    the new one goes in and will press in when you put things back together.
    Currently :
  15. #45
    Old 179's Avatar
    Southwest Indiana
    300
    Well? Fixed? New kit cost less then $20
