I just put new friction plates in the 350x. I put the clutch cover back on and the decompression cable is being a bi***. The cable is about the break, and the lever on the cover is not moving with the kick starter. I think if i take the case side off I can rotate the decompression shaft, so the lobe hits on the kickstarter shaft. What do you think?
