how is this done (i havve an 85 200x) and what do i gain from it.
1985 atc 110 for sale
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
uni clamp on air filter
350x front end
I would watch advancing the timing with a 12.1 piston, because if you go too far you might burn a big hole in it. Advancing the timing will give you more low end, & take away some top end, Retarding it will do the opposite, more top end power, less low end. Timing can be adjusted with offset keyways that go in the crank where the flywheel goes on.
On the cylinder head of your 200.. there is a metal cover marked CDI on it.. when you remove it there is a metal ring that has a firing mark for the rotor.. it can be moved clockwise or counterclock wise to change the time at wich the spark will happen during the compression stroke.
LEAVE IT ALONE !!!!!! DO NOT TOUCH IT !
Currently :
84 125 M - The Mini-SXnot running yet. but won't be long.
whenevr i have advanced the timing to any of my machines, it has given me no problems at all, it has enhanced my performance of my engine quit a bit, there has been no problems at all and i have had the timing advanced for a few years
my trikes:
1983 honda atc 200x-k&n filter
2002 yamaha raptor 660r, yoshimura slip on, prm grab bars
1978 chevy nova, 454 v8, bds blower, 150hp shot of nitrous, full roll cage, a real power house.
1991 chevy s10 4x4 350v8.
1986 250sx
YES its fast NO you cant ride it.
You guys are confusing ignition timing with valve timing.
Advancing valve timing gives you more low end.
Retarding valve timing give you more top end.
On a 200 you would have to buy an adjustable cam sprocket to do this, unless you just want to time it a tooth off and I dont think that will give very good results.
Advancing ignition timing gives more power everywhere. But you dont want to go to far or it will detonate. If you have a 12 to one piston be very careful! Bigredhead has that adjustment down if you're gonna try it. I would def run the highest octane you can find.
08 Outlaw 525s
07 CRF70
04 Harley FLHRCI
04 TRX90
03 XR650R
03 400EX- XR650R engine
02 XR100R
01 Banshee
00 XR50R
00 XR70R
99 PW50
99 JR50
96,95 Sportsman 400
95 Xplorer 400
94 Indy XLT
87 Trail Boss
86,86,86,86,86 Scrambler
86 TRX70 x2
85 ATC350X
85,84 ATC250R
85 Red Tecate
85 LT50 x2
84 XR500R
84,84,84,84,83,82,80,79 ATC70
82,79 XL500R
83 ALT50
79,78,77,77,76 XT/TT500
76,75,74 XL70
72,71,71,71 SL70
72 Harley FX
72,71,70,70,70,70,70 CT70H
72 SL100
70,69 Z50
ok hotroddal how do you advance it when you do it? and is it harder to start?
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
350x front end
I think Jason Hall is talking about 2 stroke timing, advanceing the timing or retarding it alters the port timing of a two stroke so it can shift the power band up or down to some degree.
I think this is why go-ped guys will run 12 degree retarded timing on some of those weed wacker motors.
1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
1985 honda es 250 big red.
85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
A trike to show up the modern utilitys
2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
You will not gain enough from advancing timing on your 200 cc four stroke honda to be worth the time and potential problems involved.
Idealy you would need a timing light to see how close your current timing is by removing the flywheel timing mark cover.. then fire it up and check what you have now.
then you remove the CDI metal cover on the head.. and loosen up the 2 philips screws that hold the Rotor firing plate forward or backward by a hair... and tighten them up... recheck timing and test.....
But like i've already told you a few times already.. Leave good enough alone for the love of god.
Currently :
Oh.. and to answer the question in short form.
Advancing timing : Makes your spark plug fire bofore it's supposed to to help ignite the air/gas mixture pre-maturely on the compression stroke, It helps at high rev's as things happen so fast that having the spark at TDC ( Top Dead Centre ) is a tad too late to get optimum BOOOM from the combustion chamber.
Same applies to Retarding timing.. you make the spark happen a tad lateer than usual.
Each has it's pros and cons.
A honda 200 cc motor is meant to be a low end RMP powerplant and be reliable.. not a high rev top end monster.
What you need is an R !!
Currently :
ok, first what you do is remove the cdi cover and then remove the timing mark inspection cap and find the "T" on the flywheel then you loosen up the 2 phillip head screws that hold the golden colored plate, and then once you have done that move the plate to the right just a pubical hair then, turn the engine over so the cdi thing on the camshaft lines up with the line on the other black thing, tightne up the phillip head screws., then look back in the inspection cap and you should just barely see part of the letter T, by doing this i have noticed alot better permormance all around.
I havnt been on to much lately because since skool is out i spend most of my time in the garage, so im sorry for not answering quicker.
my trikes:
1986 250sx
advancing the timing on kickstart honda? I don't recommend it at all. i had a local shop rebuild my 250r motor once and when i put the engine in and kicked it, i sprained my ankle. i found the keyway was in the groove all the way and flywheel was advanced.
the motor will fire while you are in middle of kick, with 12:1, it is gonna hurt!
go with the slotted cam gear if you want to fool with timing. my 350x with the cam gear off one tooth would scream! 10:1 and exhaust only.
